20 Most Recent
Roper REX3614KW Electric Dryer Questions & Answers
Not heating up but runs
your resistances device is blowned , you must service your device ,if you are a self doing just replace your device resistance(s) and voila
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
Can You Set Up Dryer To Use 110 Plug ( Standard Plug)?
buy a gas dryer,that uses 120 volts.but electric that uses 240 volts can't be set up to 120 volt.,i've seen electric dryers that are set up for 120 volts but they take a very long time to dry the clothes.http://www.ajmadison.com/cgi-bin/ajmadison/LDR3822PQ.html you can look at some of them.
Where is the the reset button on roper dyer
There is no reset button on any dryer. Your Roper is a Whirlpool with a different nametag. Depending on how old it is there may be 1 or 2 non resetable fuses. They are in the back behind the rear cover. They blow when there is another problem. Such as a clogged exhaust or a bad cycling thermostat. Don't do any work on it without double checking that the machine is unplugged
