You should have manual buttons on the tv itself to control input and volume. It appears it is defaulting to antenna channel 3 and low volume when first powered on. You can buy universal remotes to control your set.
1. Power down the printer
2. Press and hold the lower left hand corner of the screen
a. This is normally where the progress bar starts loading on the screen
3. Power on the printer
4. Release the left hand corner once the "Permanent Storage Init" message appears.
or alterative way
2. Press and hold the right arrow button on the navigational bar
a. This button will flash for a moment when the printer boots up
On your remote control (with tv off) 1. press Display, channel 5, Volume Up and then Power this brings up the service mode (you will see some green text on your screen) 2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen (channel 2 cycles up through the options, channel 5 cycles down) 3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro" (channel 1 cycles up through the suboptions, channel 4 cycles down) 4. Press channel six until the default value (12:60) changes to 12:40 (channel 3 increases the value, channel 6 decreases the value) 5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write" 6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
1. Set the correct date and the Mid Button is the OK the center orange.
2. Volume is only changeable in the Music or Vidoe Player
3. to calibrate just press with your stylus on the center of the box with the cross lightly ( it calibrates the sensetivitys )
hit setup...then under AV setup...click over to the 3rd screen...and it should give you options for navagtion volume and and options for muting and overiding the sounds comming from the speakers either front left, right or both....
If u r using a bluetooth headset you may be inadvertantly muting the phone using the side buttons. When u make a call look at the main screen and see if it says unmute in the lower left hand corner. If so press the button under it and speak again and see if that works for you
