E-Machines T6524 PC Desktop Logo
Posted on Dec 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an E-Machines T6524 and the ATI Radeon Xpress 200 card that was installed on the motherboard works fine, but makes everything blurry and wavy. I have another graphics card, but it's old and I can't watch videos or anything on it. It's not my monitor, because it works fine with my other card. What's wrong with it?
Chuck N
Level 2:
  • Expert 37 Answers
  • Posted on Dec 03, 2017
 Chuck N
Expert
Level 2:
Answers
37
Questions
0
Helped
7132
Points
108
You'll need to replace the Graphics Card with one that supports the OS you are using. Look to eBay for one
5 Related Answers
Anonymous
  • 61 Answers
  • Posted on Mar 06, 2008
SOURCE: Blurry and wavy monitor
blurry visuals and wavy screen is definitely a bad monitor and these problems occur with CRT's. Is the new monitor a CRT ? if it is, start by switching it on and off a few times and if it dose not work , slap the back housing a few times to shake up things a little bit..it will probably fix itself
Anonymous
  • 1913 Answers
  • Posted on Jan 05, 2009
SOURCE: Disabled video driver. Now unable to reboot emachines T5246
reset your bios settings put cmos cell for 15 minutes. also u can reset bios with jumper settings.
then remove meory card then check beep.
then connect allconnection then try.u can do it man.
Anonymous
  • 79 Answers
  • Posted on May 31, 2009
SOURCE: Software Driver reuired
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/integrated_mce-xp.aspx?type=2.7&product=2.7.5.3.3&lang=English
Anonymous
  • Posted on Jul 29, 2009
SOURCE: Emachine T5212 Ram Issue
Did you get this problem fixed? I have the T5212 (which I really like) but want to upgrade the RAM prior to Internet 7, just in case
Thanks!
Anonymous
  • 1015 Answers
  • Posted on Sep 12, 2009
SOURCE: eMachine Video Card upgrade
Ok so are you getting video from the card? Look in system information and see what graphics hardware the computers says is installed. Are you replacing a video card or did you add a card to the system? If you are adding a card make sure that you change the settings in the BIOS to boot first on AGP/PCI-E express slot. Make sure that fast write settings and bus speed settings are compatible with your card. For example if you purchased a 8X AGP card and your computer only does 4X the card may not work. Double check that you are trying to install the correct drivers for your card and operating system.
Nvidia geforce g210
1.5.1 Graphics Subsystem
The board contains two separate, mutually exclusive graphics options. Either the integrated
graphics processor (contained within the ATI Radeon Xpress 200 Northbridge) is used, or a PCI
Express x16 add-in card can be used. When a PCI Express x16 add-in card is installed, the ATI
Radeon Xpress 200 Northbridge graphics controller is disabled.
http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
1helpful
Sm bus controller, nothing works have tried all ideas i have found. once i do get it to install, i get error i dont meet system requirements? which i dont get cause this all came as one package? T5048...
This is what you need,
http://www.intel.com/support/chipsets/sb/cs-013541.htm
Not an ATI Radeon XPress 200 motherboard chipset?
I say thee nay to the forums,
1) The eMachines T5048 Desktop PC uses an Intel D102GGC2 motherboard.
Intel Support > D102GGC2 motherboard > Product Documentation and Manuals,
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=15112&lang=eng&wapkw=%28D102GGC2%29
To the right of the first file -
File name: D102GGC2_ProductGuide_English.pdf
,left-click on Download.
On the next page left-click in the circle to the left of, I accept, etc.
[ The above is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files. {Do suggest upgrading to Adobe Reader X, (10), though, if you do not currently have it}
After you click on Download it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download ]
2) The motherboard chipset is an ATI Radeon XPress 200.
Uses an ATI Radeon XPress 200 Northbridge chip, and an ATI IXP 450 Southbridge chip.
Information on the Northbridge chip,
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges_2
Look under the Model heading;
ATI Radeon XPress 1150 (originally named ATI Radeon XPress for Intel)
Intel Essential Series
D101GCC/D102GCC
(Grand Country is the Code Name for the motherboard)
Now look under the Codename heading; {code name for the chipset}
RS400, RS415, RC400, RC410
Information on the Southbridge chip is in the table that is next.
(Comparison of Southbridges)
Primer;
The motherboard chipset is the Northbridge chip, and Southbridge chip.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, or Core i9)
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge and Southbridge chips have their directional names, from the way they are placed on the motherboard, for one.
If the motherboard is placed so that the Processor at the Top, and the Ram Memory is to the right, the Processor is due North.
The Northbridge chip is placed close to the Processor.
The Southbridge chip is closer to the Bottom of the motherboard, or South.
(Closer to the expansion slots)
The Northbridge chip handles the faster capabilities of a computer.
Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are High-speed graphics.
A graphics card inserted into a PCI expansion slot, or using Integrated Graphics, is Not high-speed graphics.
Anything associated with the PCI bus is handled by the Southbridge chip.
The Southbridge chip handles the slower capabilities of a computer.
Anything connected to,
1) IDE
2) SATA
3) USB
4) Ethernet
5) Audio (Codec)
Motherboard diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
In the motherboard manual, (Product Guide), go to Page 11.
The motherboard is shown rotated to the right, in comparison to how it sits in a computer.
The Processor socket is indicated by the letter H.
To the Left is a square sitting diagonally. This is the Northbridge chip.
The Northbridge chip has an aluminum finned Heatsink sitting on top of it,
http://www.ascendtech.us/itemdesc.asp?ic=MB4INTD102GGC2&eq=&Tp=
Click on the small photo of the motherboard to enlarge.
Processor socket in the foreground, Northbridge chip with aluminum finned Heatsink, sitting on top of it.
[ The Southbridge chip also has a Heatsink sitting on top of it. It's to the top left corner of the Northbridge heatsink, in the photo ]
Notice the wording for the motherboards brief specifications in it's heading.
The last specifications stated; ATI RC410 Chipset MBoard.
ATI RC410 MotherBoard Chipset.
In otherwords ATI Radeon XPress 200.
For additional questions please post in a Comment.
Regards,
joecoolvette
Need a smbus controller for an emachines t6524..anyone? thanks so much
Go to this download page HERE. This is for the Radeon Xpress 200 motherboard chipset. Select the motherboard/ IGP catalyst download. When installing it will stop and ask what you want to install. Select southbridge driver.
3answers
I need the audio & vedio driver ddr101
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
1helpful
I have intel D102GGC2 motherboard with ati radeon xpress 200.can i play movie smoothly in windos 7 32 bit? i have p4 processor.
ATI Radeon xpress 200 driver is installed automatically in windows 7, however if you face problem with the drivers you can download the latest drivers from the links below
Download ATI Radeon Xpress 200 WDM Integrated Driver v.10.2
Download ATI Radeon Xpress 200 Catalyst Software Suite v.10.2
if you require more assistance regarding this feel free to reply to this post
Regards-BA
1helpful
ATI Radeon Express 200 series comapred to ATI Radeon 8500
Hi. The ATI Radeon Xpress 200 is better than the Radeon 8500.
Will intel D101GGC support ATI Radeon 8500?
yes, before you buy video card
verify first the interface slot available on *********** board (AGP,PCI or PCI Express)
then select the video card with the same interface in *********** board
verify the video cards driver if compatible to your operating system
before installing the video card update your BIOS to latest version
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
