20 Most Recent E-Machines T6520 PC Desktop Questions & Answers
the system board should be labelled where the jumper pins connect. if you are in the right spot, but the lights dont work, then flip the connection around, because LED lights are polarized, meaning they will not light up unless the + and - are plugged in correctly. Usually, the wire with the COLORING on it is the + and the white, gray, or black wire is the -
E-Machines T6520... | Answered on Dec 04, 2014
On a Asus motherboard its not designed for eMachines systems because they come with a proprietary setting on the case. So what you need to is take the emachines motherboard that you took out and take the new motherboard that you bought and match the two. If there is a difference then you need to return it or buy a new case and you shift all the hardware from the emachines to the new case. If not buy a similar replacement board from emachines or ebay and you can find one and buy it. The Power setting is on all motherboards but some are different then others.
E-Machines T6520... | Answered on Apr 11, 2014
red white is the pair that supplies power it should be 2pin socket on motherboard
Yes as long as your T6520 comes with at least a 400 watt power supply. It has the required 16x PCI Express slot.
E-Machines T6520... | Answered on Feb 20, 2013
Open Control Panel, Device Manager, Sounds, Is the audio device listed? Enabled? The Windows XP drivers can be found here, install and reboot: http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1645
E-Machines T6520... | Answered on Feb 01, 2013
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
E-Machines T6520... | Answered on Oct 02, 2012
You could be right in your analysis, however, before replacing the PSU unit (a weak point with both Medion and E-machine computers) check the following:
  • That the Power button is not sticking in the case
  • Inside the computer case, the PW wire is firmly making contact with the motherboard (switch to motherboard 2 pin wires)
  • That the PW wire does not have a kink in or is broken giving an intermittent fault
After checking those:
  • Disconnect HDD, DVD Writer, remove 1 stick of ram and test with each removed, replacing each in turn. If the computer still does not boot, then check the ATX connector to the motherboard and the 4 pin auxiliary CPU connector (black and yellow) if fitted
  • Remove the motherboard and check underneath to make sure there are no items of metal that might be causing the board to short out. Check the board underneath for signs of blacking or burning.
  • Replace the board and refit all connections.
  • Inspect the capacitors on the board (small cylinders) if any are bulging at the top, leaking and with a brown residue, the board is failing and will need replacement.
  • Finally, remove the PSU and test with a known good one.
  • If this fails and the board shows no blowing capacitors, the problems may now lie with a blown CPU or micro damage to one of the motherboard circuits
E-Machines T6520... | Answered on Jul 18, 2011
Hello
Try reseating the video card in the pci slot,remove completly then reinstall.
Also check your monitor video cable for being tight.
Last..Does this card require 24 volts? check for a 4 pin adaptor plug on the card.It may need its own power.
E-Machines T6520... | Answered on Apr 22, 2011
It might be a video card, or maybe a lose connection, or even a bad monitor.
E-Machines T6520... | Answered on Mar 05, 2011
disconnect all the external devices, try to boot the computer in safe mode by pressing F8, if it doesn't boot in safe mode then you may need to reinstall windows on your computer.
E-Machines T6520... | Answered on Dec 28, 2010
Maybe you should try to do a "destructive" restore. when restoring from the recovery disc, you have the option to do a "destructive" or "none destructive" system recovery. if you choose to to non destructive recovery, then any virus that may be on your pc will not be removed and this may be the reason why your recovery always stops half way through. note that this will format the hard drive and you will loose all the files on the hard drive, including photos and documents. if this doesn't work then you should try to find out if you have a hardware problem. you can download one diagnostic software from seagate, that you burn to a cd. you use this as a boot disc, like the recovery disc, to test your hard drive, memory and motherboard to see if you need to replace any components. the most common problem is the hard drive. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
E-Machines T6520... | Answered on Oct 26, 2010
This can be because of virus infection, there are so many applications on your start up and low virtual memory.
But my best suggestion is for you to run a virus scan on your computer so it can detect viruses, worms and malware that you get in surfing the internet or by just sharing files. If this will not work you need to re-install your OS so your computer would be like brand new.
E-Machines T6520... | Answered on Sep 12, 2010
Sounds like it might be your power supply, you may need to replace it. Emachines are known to have their power supplies go out quickly. I would go to bestbuy or frys electronics and buy a new power supply, costs about 50 bucks. To install it is quite simple just open your pc and unscrew where the big box at the top where the power cord usually goes into.
E-Machines T6520... | Answered on Sep 02, 2010
Try continually pressing the F8 key as it starts. You may be able to start it in 'safe mode'.
You haven't got a usb flash drive in one of the usb ports, have you? That can sometimes cause the problem you describe.
Any error messages apperaing on the screen? Don't forget the monitor cable ...
E-Machines T6520... | Answered on Aug 30, 2010
I'd like you to check some components on the motherboard.
Specifically, Electrolytic Capacitors.
More specifically, the one's used in the motherboard Voltage Regulator Circuit.
This is a leading cause of a computer booting up, then shutting down, then restarting again.
eMachines are a budget computer. The low cost, is due to low quality hardware components inside the computer..
Electrolytic capacitors on the motherboard, being some of the above stated components.
1) Electrolytic Capacitors slowly build a charge up, then release the charge all at once.
Akin to a swimming pool slowly being filled up by a garden hose, then one wall of the pool is taken down all at once.
The Electrolytic capacitors used on the motherboard, are aluminum Electrolytic Capacitors, and are Radial in design.
http://en.wikipedia.org/wiki/Electrolytic_capacitor
Viewing the second photo down, at the top right of the page, the bottom Electrolytic Capacitor is of the radial design.
Both leads come out of the bottom.
Essentially, an aluminum Electrolytic Capacitor is a small aluminum 'can', with three strips of thin foil rolled up together, inside.
A) One strip is metal, and is the Conducting strip.
B) One strip is also metal, but has a non-conducting medium applied to it.
C) The last strip is composed of a paper-like material, and is soaked with Electrolytic Paste.
The paper strip is placed between the two metal strips, and all three strips are rolled up tightly, then inserted into the 'can'.
(Of the two leads that protrude from the bottom of the capacitor, one is a Positive lead, the other is a Negative lead.
The Positive lead is connected to the Conducting strip.
The Negative lead is connected to the Non-Conducting strip)
At the bottom of the 'can' case is a seal. This seal is composed of a synthetic rubber-like material, and is a flat disk shape.
At the top of the 'can' case is another seal. It is a thin, flat, disk of metal.
The center of this disk shape has an X, or K, etched partially into the disk.
Electrolytic Capacitors break down over time.
The design manufacturer of a product that uses this type of capacitor, is aware of this, and plans accordingly.
The capacitor used is 50 percent better than is required.
This way as the capacitor breaks down, it weakens to a state that is still usable.
Low quality Electrolytic Capacitors have inferior Electrolytic paste.
As the paste breaks down a gas is formed. (Hydrogen gas)
The gas expands inside the can's case, and slowly pushes the Electrolytic paste out.
(Oozes out)
When the capacitor is starting to break down, the outside can case bulges.
As the capacitor breaks down further, the paste is pushed out of the bottom seal, (Rubber like disk has one side pushed out of the bottom), and/or breaks the etched design on top open, and paste pushes out.
So much paste loss, and the capacitor can operate in a weakened state.
Too much paste loss, and the capacitor fails.
The paste can also dry up inside, and will show no outward visual signs of failure.
Computer unplugged from power, computer case open.
TOUCH (Not 'shouting') the metal frame of the open computer case, BEFORE you reach inside, to relieve your body of static electricity.
[Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
You may not even see it, or feel it.
Computer unplugged from power you are safe.
TOUCH the metal frame, and your computer is safe.
Work on a table.
Do Not work on a bed, or directly on a carpet floor. These are high areas of static.
Should you get up, and walk away in the middle of working on your computer, be Sure to touch the metal frame upon your return]
See if you can observe visual signs of capacitor failure.
http://www.capacitorlab.com/visible-failures/index.htm
A video showing the results of capacitor failure, in the motherboard Voltage Regulator Circuit,
http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
Part of what the motherboard Voltage Regulator Circuit does, is to regulate voltage for the Processor.
The Processor must have a steady, clean, supply of voltage, and the voltage must be within a certain range.
Too much, or too little voltage, and the Processor turns off.
(BIOS turns the Processor off)
Failing Electrolytic Capacitors in their weakened state will charge up, and release for a brief time period, but then will break down.
This is why the computer comes on, then shuts down.
Replacing the motherboard is the solution.
One more 'ailment' may apply.
It could be Electrolytic Capacitors in the Power Supply, that are breaking down.
Test the Power supply voltages, or replace the Power Supply with a KNOWN to be good, working unit that is compatible, for a test.
(Compatible being the Power Supply is the correct size, and shape, plus also has enough Wattage, and the correct amount of power cables, plus the correct power cables)
To test you will need a multimeter, or a power supply tester.
A computer (Personal computer) Power supply puts out three main voltages.
A) 3.3 Volts. (Wires with Orange insulation)
B) 5 Volts (Wires with Red insulation)
C) 12 Volts (Wires with Yellow insulation)
If the 12 Volt power rail is 11 to 13 Volts, the power supply is okay.
Below 11 Volts requires replacing the Power Supply.
You can post additional questions in a Comment.
E-Machines T6520... | Answered on May 26, 2010
flogue
The clicking sound is not related to the CD or ROM drive but an issue with you hearing the bus noise through the speakers.
Question if you play an MP3 do you hear the same sound. Note CD-Audio playback is handled differently then playing a DVD. The CD audio signal is still analog so the back ground interference can effect the audio you hear.
If you other audio sources do not have a problem then I would recommend getting and IDE cable with more shielding on it to see if this makes a difference. Another option is if you have an extra SATA connection you might try getting a SATA ROM drive to see if you still have the problem. Also another way to go is to disable the on-board sound card and install a PCI one in the system.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
E-Machines T6520... | Answered on May 25, 2010
You will need to do a fresh install as the file windows needs to start is corrupted.Run the restore cd once more and re-install the os.
Good Luck
E-Machines T6520... | Answered on Jan 17, 2010
I assume you are looking to connect another hard drive in your computer.
Most desktop computers have two IDE controllers.
The 1st controller will have the "C" drive set to Master (MA) and there maybe another drive CD or DVD drive on the same IDE cable, if so the drive will be set to Slave (SL) or if you intend to install a drive on this cable.
The 2nd. IDE controller and cable can have hard drive or CD/DVD drives too but the drives must be set to either Master or Slave - BOTH drives in the one cable CANNOT be set the same.
Most CD/DVD drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS).
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
E-Machines T6520... | Answered on Nov 29, 2009
Its probably your graphics card or driver. Try changing your screensaver to one without animations, if that fixes it you need to look into your graphics processing.
E-Machines T6520... | Answered on Mar 26, 2009
E-Machines T6520 PC Desktop Logo
30 questions posted
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T E-Machines
  • T E-Machines
Most Popular Question
one our network e machine computer keeps
  • Computers & Internet
