20 Most Recent E-Machines T5048 (7136) PC Desktop Questions & Answers
At power on, enter the bios (usually by tapping a function key like Tab or Del or F2) and change the boot device order to have the CD drive first. Put the disc in the disc drive. Save and continue. Now, you may get a message asking you to "press any key to boot to the CD". Touch any key, and the reload should start.
See...
http://pcsupport.about.com/od/fixtheproblem/a/biosaccess_pc.htm
E-Machines T5048... | Answered on May 18, 2014
Try another monitor to verify the Graphics Card, if you have a graphics card, then another monitor cable. check for bent pins in the connectors, eliminate the hardware by changing each component/cable one by one. It may be the Graphics Card/Adapter is gone. Clean the inside of machine, overheating due to dust will cook components, GPU's get quite hot. Try some Electronic Contact cleaner spray on the Graphics Card connections, if applicable. Unplug before reseating the Graphics Card or cleaning, take precautions in ESD before handling a Component. If your Graphics is integrated, you can purchase a aftermarket PCIe x16 Graphics Card quite reasonably, : http://www.google.com/webhp?source=search_app#q=ati+amd+pcie+x16+graphics+card&hl=en&sa=X&tbs=vw:l,p_ord:p&tbm=shop&ei=ze05Uf25KJDO9ASIyYHYDw&ved=0CF8Quw0oAg&bav=on.2,or.r_qf.&bvm=bv.43287494,d.eWU&fp=bc2048b0dd90d6d4&biw=854&bih=580
E-Machines T5048... | Answered on Mar 08, 2013
eMachines T5048?
Suggest you enter BIOS Setup, and in Boot Options, set the first boot device to CDROM.
This makes the computer boot from the Recovery disk.
How to enter BIOS Setup? (May be called CMOS Setup also, but I don't believe the computer is that old)
Look at the bottom of the monitor screen, as soon as the eMachines logo comes up. It will state what key to press to - enter BIOS Setup.
Usually it's the DELete key, or F2 key,. for eMachines. May be the Tab key.
Window of opportunity went by, and you didn't get into BIOS Setup?
S'okay. We just need to know what key to press, for now.
Got the key written down?
Open the optical drive, and put the Recovery disk in. Close the optical drive tray.
Now hold the Power On button in, and for a count of 10 seconds.
Turns the computer off.
WAIT 1 minute, turn the computer on.
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup key.
Tap in 2 second intervals.
Hear beeps? Ignore them. They are Stuck Key Error Code beeps, and it is you that is doing it.
Takes a few seconds. Now you should be looking at the BIOS Setup utility, and the Main menu.
BIOS Setup utilities change from computer to computer.
That's because there are 3(?) major BIOS manufacturing companies, and each BIOS has a different version.
(Phoenix/Award and AMI)
The menu headings may go across the top.
Just one example;
Main / Advanced / Power / Boot / Exit
Or they may be listed in a column,
http://www.buildeasypc.com/sw/bios_setup.htm
http://www.computerhope.com/help/phoenixa.htm
(Scroll down a little)
http://www.daossoft.com/documents/boot-from-cd-award-bios-setup.html
When in the BIOS(CMOS) Setup utility, you CANNOT use the Mouse anymore. You have to use the Keyboard to navigate around.
With the menu's going across the top, for example; you would use the Right Arrow key, and highlight -> Boot
Then press the Enter key.
With menus that are in a column, use the Down Arrow key to highlight Advanced, or Advanced BIOS. (Or Advanced CMOS)
Press the Enter key.
You will see - First Boot Device, Second Boot Device, Third Boot Device, and Boot from other.
To the right you will see the various devices, the computer can boot from;
HarDDrive, (HDD-0), CDROM, Floppy, Internet, etc.
You want CDROM to be to the right of First Boot Device.
If the devices are just listed in an order, you want CDROM at the Top.
With First Boot Device, Second Boot Device, etc listed;
Use the Down Arrow, and highlight First Boot Device.
Your cursor will now be in the device order list.
Use the Down Arrow key to highlight CDROM.
Now look at the navigation guide at the bottom.
To move CDROM to the Top, you may press the;
Page Up/Page Down key, or the +/- key. (Plus/Minus key)
Depends on what is listed in the navigation guide at bottom.
(If +/- key just press the - key)
With CDROM at the Top press the Enter key.
Things differ here too;
A small window may come up asking, Save Changes?
It may show F12 - Save Changes
Or it may show a Y for Yes, and an N for No
(Or Yes/No)
If F12 just press the F12 key, and the computer will restart.
If you have the Recovery disk in the optical drive, the computer will now boot from it.
If Yes/No, or Y/N; use the appropriate Arrow key, and highlight Y, or Yes.
(Note: If Y just press the lower case y. The uppercase Y is just shown for clarity)
If the Recovery disk is in the optical drive, the computer will boot from it.
Recovery disk isn't in the optical drive? No sweat. Put it in there.
Now press the CTRL key, ALT key, and DElete key AT THE SAME TIME.
This makes the computer restart.
If you have never approached this procedure before, it probably looks like, "Wa-wa-wa".
(That's what my niece states when I try to explain computer technology. Wa-wa-wa from the Peanuts cartoon. lol!)
You pull up the BIOS Setup utility, and tell me what you see.
You'll be my eyes, and I'll step by step you through it.
We will post back, and forth in a Comment.
Regards,
joecoolvette
E-Machines T5048... | Answered on Feb 11, 2013
Microsoft website has any drivers you need....
Just go to their web site ,
And search for your drivers and download for free( personal exp.)
Tc,
Eric
E-Machines T5048... | Answered on Feb 08, 2013
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
E-Machines T5048... | Answered on Jun 13, 2012
This is what you need,
http://www.intel.com/support/chipsets/sb/cs-013541.htm
Not an ATI Radeon XPress 200 motherboard chipset?
I say thee nay to the forums,
1) The eMachines T5048 Desktop PC uses an Intel D102GGC2 motherboard.
Intel Support > D102GGC2 motherboard > Product Documentation and Manuals,
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=15112&lang=eng&wapkw=%28D102GGC2%29
To the right of the first file -
File name: D102GGC2_ProductGuide_English.pdf
,left-click on Download.
On the next page left-click in the circle to the left of, I accept, etc.
[ The above is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files. {Do suggest upgrading to Adobe Reader X, (10), though, if you do not currently have it}
After you click on Download it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download ]
2) The motherboard chipset is an ATI Radeon XPress 200.
Uses an ATI Radeon XPress 200 Northbridge chip, and an ATI IXP 450 Southbridge chip.
Information on the Northbridge chip,
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges_2
Look under the Model heading;
ATI Radeon XPress 1150 (originally named ATI Radeon XPress for Intel)
Intel Essential Series
D101GCC/D102GCC
(Grand Country is the Code Name for the motherboard)
Now look under the Codename heading; {code name for the chipset}
RS400, RS415, RC400, RC410
Information on the Southbridge chip is in the table that is next.
(Comparison of Southbridges)
Primer;
The motherboard chipset is the Northbridge chip, and Southbridge chip.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, or Core i9)
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge and Southbridge chips have their directional names, from the way they are placed on the motherboard, for one.
If the motherboard is placed so that the Processor at the Top, and the Ram Memory is to the right, the Processor is due North.
The Northbridge chip is placed close to the Processor.
The Southbridge chip is closer to the Bottom of the motherboard, or South.
(Closer to the expansion slots)
The Northbridge chip handles the faster capabilities of a computer.
Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are High-speed graphics.
A graphics card inserted into a PCI expansion slot, or using Integrated Graphics, is Not high-speed graphics.
Anything associated with the PCI bus is handled by the Southbridge chip.
The Southbridge chip handles the slower capabilities of a computer.
Anything connected to,
1) IDE
2) SATA
3) USB
4) Ethernet
5) Audio (Codec)
Motherboard diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
In the motherboard manual, (Product Guide), go to Page 11.
The motherboard is shown rotated to the right, in comparison to how it sits in a computer.
The Processor socket is indicated by the letter H.
To the Left is a square sitting diagonally. This is the Northbridge chip.
The Northbridge chip has an aluminum finned Heatsink sitting on top of it,
http://www.ascendtech.us/itemdesc.asp?ic=MB4INTD102GGC2&eq=&Tp=
Click on the small photo of the motherboard to enlarge.
Processor socket in the foreground, Northbridge chip with aluminum finned Heatsink, sitting on top of it.
[ The Southbridge chip also has a Heatsink sitting on top of it. It's to the top left corner of the Northbridge heatsink, in the photo ]
Notice the wording for the motherboards brief specifications in it's heading.
The last specifications stated; ATI RC410 Chipset MBoard.
ATI RC410 MotherBoard Chipset.
In otherwords ATI Radeon XPress 200.
For additional questions please post in a Comment.
Regards,
joecoolvette
E-Machines T5048... | Answered on Sep 21, 2011
Drivers for your computer can be downloaded from here.
E-Machines T5048... | Answered on Jul 19, 2011
Either a mismatch in ram bus speeds or timings. assuming the modules are seated correctly.
E-Machines T5048... | Answered on Jan 05, 2011
You will need to download the sound card driver. If you have the driver discs which shipped with the PC, the driver should be located there.
If you don't have the discs you still have a few options.
go to the windows update site and search in the optional/ non-critical updates. Many times Microsoft will provide the drivers.
if that doesn't work you can go to the E-machines support page and search for drivers and downloads.
from there you will be prompted for the model and serial number of your PC.
you will then be presented with a list of available drivers.
select the sound card driver for your operating system
E-Machines T5048... | Answered on Jan 04, 2011
No, This model does not has WiFi, but you can always connected a wireless adapter to use WiFi.
E-Machines T5048... | Answered on Sep 21, 2010
Yes, as you can see here
http://www.emachines.com/products/products.html?prod=T5048
your desktop doesn't have a WiFi card.
E-Machines T5048... | Answered on Sep 08, 2010
You may get it by installing the driver of sound or your sound device may be out of order
thanks
E-Machines T5048... | Answered on May 17, 2010
You can find 3 jack hole in the back side of cpu.Those are jack for sound cable.
Check in back side of cpu you can find 3 hole pink-green-blue.
Connect audio cable from speaker to green hole it is for audio And connect another cable of mic to blue then it will work.
Let me know if you need further assistance.
Thanks for using FixYa.
May I get the make and model # to help you more.
did you touch any setting in the control panel or audio box
E-Machines T5048... | Answered on Mar 28, 2010
Your camera probably came with a cable that helps you do this. The cable has a rectangular USB connector on one side, and a smaller trapazoid connector on the other end. This cable connects your camera to your PC. The cable goes into the side of your camera, and the larger end goes into the BACK of your computer. There are usually 2-6 USB connectors on the back of the computer. It doesn't matter which one you connect the camera to - they're all the same. When you connect the camera, your computer should automatically come up with instructions. Good luck!
E-Machines T5048... | Answered on Mar 03, 2010
Hi
thank you for your query
Your motherboard will have 3 slots for memory, with a maximum support of 2GB.
The type of memory you have in there is DDR 184 Pin 40 MHz
I hope this has been useful
E-Machines T5048... | Answered on Mar 01, 2010
to check how much memory is installed go to your control panel. under control panel look for system> click on that icon. it will then show the installed memory on your system
Hope it helps!
E-Machines T5048... | Answered on Feb 18, 2010
can you tell me more about the computer. Does it display anything at all?
E-Machines T5048... | Answered on Feb 17, 2010
E-Machines T5048 (7136) PC Desktop Logo
Popular Tags
59 questions posted
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T E-Machines
  • T E-Machines
Most Popular Question
put in op sys disk reload operating
  • Computers & Internet
