20 Most Recent E-Machines T3256 PC Desktop Questions & Answers
Ok! i need help with
Check to see if unit works with other disks. If it works fine then it is definitely a software issue that is preventing playback of your disk. Install VLC freeware and see if that plays it back.
9/22/2017 1:25:08 PM • E-Machines T3256... • Answered on Sep 22, 2017
3answers
T3256 needs ethernet driver
Dear Cedrich,
I found an "unofficial" e-machines website for you: http://www.e4allupgraders.info/
And the following is a link to your Ethernet driver:
http://www.e4allupgraders.info/dir3/files/drivers/lan/AU31_Ethernet_xp2k.zip
Here is the page for your particular model:
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31_downloads.shtml
If you need any further assistance, please request it,
Jem
2/1/2015 5:19:53 AM • E-Machines T3256... • Answered on Feb 01, 2015
5answers
My dvd drive in my computer won't play dvds
I recently got my computer fixed and in order to fix it they had to clear everything off my computer so it was like a new one when i got it back but now it wont play my dvds
11/19/2014 9:41:43 AM • E-Machines T3256... • Answered on Nov 19, 2014
Restore emachine without disk
All the Emachine's I worked with have a Restore Partition .... might try that first.... after the boot screen hit the F8 key and look for an option called Directory Restore Service.... if you still want the Ethernet Controller Driver try a program called Unknown Device Identifier you can find it on download.com it can help you find the manufacturer and model for your devices ...might be a good start
10/13/2013 9:51:38 PM • E-Machines T3256... • Answered on Oct 13, 2013
Need ethernet driver in
You haven't specified your operating system. You will find the drivers you look fo, here: http://www.via.com.tw/en/support/drivers.jsp
9/4/2011 9:50:33 PM • E-Machines T3256... • Answered on Sep 04, 2011
I've been trying to get
Go to Microsoft.com./downloads. You want the ESSENTIAL CODEC PACK. Follow the instructions.
8/9/2011 3:43:52 AM • E-Machines T3256... • Answered on Aug 09, 2011
My emachine Has a disk
may be you problem is not that but be sure to enter set up bios configuration an check if hard drive is detected if not choose auto and save and exit bios then let it boot normally...it might help!
7/2/2011 9:30:38 PM • E-Machines T3256... • Answered on Jul 02, 2011
I have a t3656 emachine. all of a sudden it just
This error comes when the OS system files are corrupted .
You need to re-install OS.
Thanks for using FixYa.
5/28/2011 7:37:34 PM • E-Machines T3256... • Answered on May 28, 2011
My emachines t3256 is running
This is not necessarily a problem. The computer will utilize the cpu when it needs to, meaning, you are not putting much of a burden on the cpu if it is only running at 1GHZ. When you start to do more task, run more programs etc, you will see the CPU utilization increase!
I hope this is informative.
Regards,
G33k
5/6/2011 1:19:21 AM • E-Machines T3256... • Answered on May 06, 2011
Where do i get drivers
Hello sage_morales,
A backup restore cd should have been created when the computer was first installed. But if you don't have the restore cd then this link on the emachines support site may have helpful information:
http://emachines-us.custhelp.com/app/answers/detail/a_id/2631/related/1/session/L2F2LzEvc2lkL3p0UXgzcXNr
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
4/26/2011 4:05:26 AM • E-Machines T3256... • Answered on Apr 26, 2011
Hi, i hope you can
Restart the computer, when you see the Emachine logo, tap F8
go to safe mode
Once in safe mode, go to start, all programs, accessories, system tools system restore
restore to 1 week previous that you downloaded the malware. The software that you are getting hit with is a virus itself called "Hijack Ware"- it basically holds your system hostage.
Now after that is done, go to a site like Avast! or AVG and install an antivirus (Both of those are free and reputable. I prefer Avast!)
Don't click and don't believe crud like those popups ever again. I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
12/15/2010 7:55:52 AM • E-Machines T3256... • Answered on Dec 15, 2010
Why wont my dvd drive
I suggest that you clean it first using some soft of air blower, maybe there is something stuck in there. just make sure the computer is not switched on.
One more thing, take the driver out of the the boot sequence from BIOS if the noise happens when the computer starts up.
Also, check with the manufacturer if it is still under warranty. Sometimes if you have used a shatter, it could damage the drive gears.
If it is too old, perhaps you would want to replace it with a new one because maybe there is drive failure that cannot be fixed.
11/1/2010 4:35:59 AM • E-Machines T3256... • Answered on Nov 01, 2010
I was just doing some
Check all your cable connections, inside and out.
9/24/2010 5:30:16 AM • E-Machines T3256... • Answered on Sep 24, 2010
I cannot access my internet
I HAVE HEARD U R PROBLEM just go to mozilla firefox and downlad ie8 if u dont have net connection then click on start button and select set program acess and default and click microsoft
9/23/2010 2:58:52 PM • E-Machines T3256... • Answered on Sep 23, 2010
Need motherboard drivers to connect
No you can Extract them in any Folder, thereafter Install the Drivers.
8/9/2010 5:01:56 PM • E-Machines T3256... • Answered on Aug 09, 2010
E-machines T3256 shuts down when i play games or i
Try to install a new antivirus and keep updating (Avira,Kaspersky)
7/27/2010 3:49:42 PM • E-Machines T3256... • Answered on Jul 27, 2010
My hp pavilion dv7-1133d won't
http://www.videolan.org/vlc/
Download the above player and will play them
7/19/2010 3:25:06 AM • E-Machines T3256... • Answered on Jul 19, 2010
Will not open....stalling at welcome....is this a
No, it's a software problem, most likely the chipset driver is corrupted. If you're lucky the cause of the corruption hasn't destroyed any other file and in that case you will be able to boot in Safe Mode - in there update all your drivers.
If you fail to load into Safe Mode then the damage is to great - your last hope to avoid a full reinstall and lose everything in the process is to perform a Repair: boot from cd and skip the first Press R for repair and go the setup and after you press F8, use the R for repair and it will check and replace all your system files.
6/13/2010 7:31:19 PM • E-Machines T3256... • Answered on Jun 13, 2010
E-Machines T3256 PC Desktop Logo
Popular Tags
46 questions posted
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T E-Machines
  • T E-Machines
Most Popular Question
t3256 needs ethernet driver
  • Computers & Internet
