SOURCE: Simple drive external backup
You need to use the Storage Sync program provided with the drive. You can get the latest version at the Simple Tech website
SOURCE: Simpletech 500 gb external usb drive
The external hard drive can be fomatted by :
Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
Right click on the drive you will get the popup menu.
In that select the format option.
But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
Use the full format option.
Wait for sometime, until the format is completed.
Then you are good to go.
Good Luck.
Live, Love, Laugh.
SOURCE: SimpleTech hard drive not found by my computer
You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
SOURCE: Simpletech external portable drive not working due to power surge
Then you should not connect the adapter, I think your HDD is fried, because these HDDs are USB powered, they do not need any extra power. That’s why HDD data cable comes with two USB 2 pins , one is for data and other is purely for power.
SOURCE: computer does not recognize simpletech
I have a simpletech external drive that was working, but after i disconnect it unproperlly, i was getting the message <usb not recongnize>. I called simpletech, but customer service is ****, and anyway the drive inside is a hitahi, i have another simpletech and the drive inside is a western digital, whatever...
They told be to go to best buy to make a recover, so i called and they told me it s 250$, and if they cant do it, they will send it to a labotory witch cost 1700$, crazy ******* hein?
I red about getting drivers, putting the hdd in a fridge and much more stupid thing, BUT THE SOLUTION IS SIMPLE, OPEN THE CASE, UNDER THE ALLUMINIUM STICKER THERE IS 2 SCREWS, REMOVE THEM, OPEN THE CASE, TAKE THE HDD INSIDE OUT AND REMOVE THE ADAPTER CONNECTED TO THE HDD(WHERE YOU CONNECT THE USB CABLE) CAUSE THIS IS THE PART CAUSING THE PROBLEM, THE HARD DRIVE IS OK AND YOU DIDN T LOOSE NOTHING. So now what you can do is just buy a new case for laptop hard drive (with a new usb adapter included), or buy another simpleshit hdd and switch the adapter part or just buy an adapter to make your hdd an usb hdd and Voila, and after that i suggest you buy yourself a better hdd than simpleShit and make a new backup.
