20 Most Recent
SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive Questions & Answers
Nexxtech external USB hard drive stopped working.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seatedif this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
a cnet rview
Pros: Lots of space, very low price, doesn't require outside power
Cons: Sometimes stops working, no firewire (but still a quick transfer speed)
Summary: This doesn't require outside power, but sometimes you need to hook it up to 2 USB ports. The USB cable has 2 heads. Sucks when I only have 3 USB ports on my laptop.Also sometimes it spontaneously stops communicating with the computer. I don
I have a Verbatim portable
This is a common problem with external drives,
I have had it happen to Segate, WD, and a few off brand drives. Usually
when one of these drives gets flaky, you have 2 options:
1. do a google search on your particular model on how to remove the drive from the case, then install in a desktop computer
2. use disk recovery software to attempt retrieval of files
The
first on will work if there is a problem with the driver interface to
usb board that is built into your device. By installing in a desktop, you are bypassing this potentially bad part. This step will also make the 2nd option run faster if you have to resort to it.
A good rule of thumb on these devices is to never have only 1 copy of the data.
Good luck retrieving your data!
John Vickers
I have the toshiba external
im not familiar with this NIT back up
have you tried running the chkdsk utility
administrive tools,computer management ,disk management right click on your
drive select properties click tools you should see click check now click start
tick in two boxes automatically fix files and scan for and attempt recovery of
bad sectors place then a tick in both boxes then select check now,start should
schedule this task when restart
do not do anything while
the chkdsk utility is in progress any input may damage your computer http://www.nit-solutions.net/index.php?option=com_frontpage&Itemid=1 http://www.nit-solutions.nethope this will help you
When hooking up my 120
hi
The SimpleTech SimpleDrive Portable external hard drive features a USB 2.0 interface for speed and plug-and-play connectivity. The hard drive is USB -powered, so no extra power supply is needed.
please send me 4 thumbs up
I have a 1 TB
The hard disk inside it doesn't responds to the controller - hardware failure, the disk has failed.
Nothing can fix that, your unit is truly dead and you need a new one.
administrive tools ,computer management ,device manager scroll down universal
serial bus controllers you should see a yellow question mark?
drivers
make sure the lead/s that
attach to this drive have a secure seating and are not bad/faulty the light on
only tells that its getting power it might not be getting enough power you
might test the lead/s or
fine again, sometimes the wires inside the cable will be damaged due to bending
unforeseen problems hope this helps
DOES THE VERBATIM HARD DRIVE
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32
FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS
NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
How do I get a
You will need a 12V, 2A tip positive power supply. You can purchase a power supply from many places. If you are under warranty, please call HitachiGST Tech Support M-F 8AM to 6PM
PST at 1.888.426.5214 and a technician will be happy to help you.
