Eureka WhirlWind 4381 Upright Vacuum Logo
Posted on Jun 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Eukerka lite speed
How do I change the belt on a eureka lite speed, belt is a U thanks
Anonymous
Level 3:
President:
  • Master 1,673 Answers
  • Posted on Jun 12, 2008
Anonymous
Master
Level 3:
President:
Answers
1673
Questions
Helped
704575
Points
3439
There are 2 screws on the top cover, remove those and the cover comes off, then you can get to the brush roll and belt. Inspect the brush roll, make sure the ends turn freely, if not, then replace it also.
2answers
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
1helpful
A BELT FOR THE VACCUM CLEANER (EUREKA)
Here's a link to this exact belt for your vacuum cleaner on our website:
http://www.govacuum.com/1555.html
I hope this information helped you! Please be sure to rate this helpful if it did so other Fixya users with this vacuum can easily find this belt.
Thanks,
Chris J.
GoVacuum.com
14helpful
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
8helpful
How do I change belt for Eureka Whirlwind Lite "Boss" model 450 A
Remove the 4 screws on the yellow top of the vacuum. The yellow plate will pop up exposing the belt and roller.
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
2helpful
2answers
Belt location
If you torn the macine over, at the bottom of the sweeper you will see the belt on on side. You have to take the bottom part apart and remove the brushes to replace the belt. I hope this helps.
2answers
Eureka 4331 (Boss Lite) vacuum doesn't pick up dirt anymore
I no more use Eureka 4331 (Boss Lite). But the most common reason for not picking up dirt might be the vacuum bag might be full. Need to be Clean or replace as recommended by the manufacturer or The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner's manual for cleaning instructions. I recommend having Eureka Power Speed for yourself. 7_21_2021_9_09_38_am.jpg
2answers
Belt locfation
You did not say which brand and model number you have, and they are different. Belts go around the brush roll and the motor shaft on most models.
Apr 20, 2008 • Vacuums
2answers
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
