Although the manual says this model shouldn't have one, this one does. The flat perf metal plate goes at the bottom on the filter chamber. The top DOES have to be removed to put it in correctly and that was the problem. The plate had been removed during a prior dis-assembly and I'd forgotten exactly where it came from.
The filter itself fits over the perf metal plate, it's to keep birds and asphalt out of the blower 8-)
Now that the motor bearing are replaced ($5 for the bearings, $60 for a set of Torx and a bearing puller) later, it sounds much better. Of course it took awhile to find the bearing puller that will *just* slip under the bearing on teh short end. That armature is a bit close.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12503&thid=680704 Need instructions to reassemble Eureka vacuum Posted by TamiLynn on Jun 18, 2008 I had to completely disassemble my Eureka Whirlwind Lite Model 410 bagless vacuum due to an excessive amount of debris that collected in an inconspicuous spot and now that I've reassembled it sounds like something from the motor is rubbing inside somewhere as if I put it together incorrectly. Do you have any schematics on what the insides should look like so I can put it together properly? Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the schematics is to contact the Eureka Factory @ the listing I will give you below. Sometimes the owners manual have the schematics in the owners manual but if not they might be down loaded from the factory website or to contact them by phone And ask for cust serv or the serv tech support or parts for the schematics. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://www.eureka.comCustomer Service1-800-282-2886 Customer Service Dept Electrolux Home Care Products P.O. Box 3900 Peoria. IL61612 Hours of Operation Monday thru Friday 8:00am to 7:30pm CST Saturday and Sunday 10:00am to 6:30pm CST Thanks, Don the Vac Man Go Ahead. Use Us.
usually, by the time that a large clog has built up in the narrow neck behind the brushes,
that is easy to find when the cover plate is removed,
some has also got into the fan impeller,
not so easy to see
and restricts suction
the fan housing is held on the front of the fan & motor with clips, it disassembles easily and the lint and such can be flicked out of the impeller
then the exhaust of the motor to the bag can be likewise cleaned
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
There are 2 screws on the top cover, remove those and the cover comes off, then you can get to the brush roll and belt. Inspect the brush roll, make sure the ends turn freely, if not, then replace it also.
On the top cover, one on each side will be a screw, take those out and the top cover should come off. While you have it off, check the brush roll to make sure it is turning freely, and replace the belt, they stretch after a short time and will give you problems.
not sure which filters you have ... i will assume you have a replacement cassette micron filter -- goes in the compartment on the front of the vacuum just lift up the handle on the compartment and swing upwards it will pull out like one large piece the filter is on the back. the cassette door will be hinged at the bottom so just pull firmly from the top and snap back in place after replacing the filter. Replacement HEPA filter cartridge --- attaches to rear of Eureka upright vacuum cleaners. Here is a pictorial or changing the filters : http://www.eureka.com/servlet/FindOwnersGuide
Question moved from Cars and trucks category.
Remove the base plate and remove the wheels and axle. Remove the hair and threads that was causing the wheel to lock up. You will need to use a box cutter or similar to remove the debris. Add a couple of drops of light machine oil and reassemble.
https://www.google.com/search?q=Eureka+Model+AS1104+wheel+not+turning
This can be because you need to adjust the tension or probably the pulley is no longer aligned. So find out if the shaft is no longer straight also if the belt requires tension.
