20 Most Recent
Eureka 4700A Maxima Bagless Upright Vacuum Questions & Answers
How to change belt on Eureka maxima 4700a
hey i had the same problem with mine, (standing over it and looking straight down) there should be two screws on the top of the yellow cover, one on each side, take those out and the yellow cover should easliy pop off. if the white ink is off the belt or the belt isnt tight than replace, once off just pop the wheel brush (which has the belt around it) up out of its socket and take off of the belt from the wheel brush and motor's metal pole, then put on the new one just like the old one was. let me know how it works out,
[email protected]
4704 manual
2 screws on lid lift off lid put handle down
Roller not moving
That is called the beater bar. You need a new belt. Remove any hair etc from the bearing while you have it apart
Reset switch
There is no reset button it as a Thermal Cut OffThis vacuum cleaner has a special thermostat that protects the cleaner in case of motor overheating. If the cleaner suddenlyshuts off, turn the switch off and unplug the cleaner.Check the cleaner for a possible source of overheating such as a blocked hose or clogged filters. If these conditions are found, fixthem and wait at least 30 minutes before attempting to use the cleaner. After the 30-minute period, plug the cleaner back in andturn on the switch. If the cleaner still does not run, then call 1-800-282-2886 for customer assistancethis link below is the manual
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
