SOURCE: my singer athena 2000 won't
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
thanks.
SOURCE: raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
SOURCE: i was given a Necchi 3102 sewing machine
There are a load of threading diagrams HERE, although your model is not listed, one may be similar enough to get you out of trouble.
As to a manual, a google search should give you several options for pdf downloads
