Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate
the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film.
After the protective film is removed it's really hard to attach it
back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain
separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the
keyboard so you know the order in which keys are attached to the
keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the
keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space
or Space bar for example) might have an additional
support bracket.Remove the key cap with the support bracket. As you see, the key hinge
stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right
sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each
other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them
together.If you following this guide to repair the keyboard, I would recommend to
keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between
these layers.In order to access and repair traces you'll have to separate to layers
from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even
harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Step 1.) Stop by a reputable replacement keyboard like this company:http://www.machinaelectronics.com/store/...
Step 2.) Find and order your key or hinge (they will help you find the right one
Step 3.) Follow the replacement guide provided for free on the site
And you're done. Its cheap, it's fast and its simple. You're welcome.
