Washer won't come on at all
Both Lid Locks are in parallel for Lid is locked signaling. when they lock. Do you take a "FL" error code for failed to lock?
I would remove the right hand lid lock and troubleshoot the Left Hand Lid lock. Only the Left Hand Lid Lock is required for the machine to operate as designed. I pulled my Right Hand Lid lock out of the machine years ago to simplify troubleshooting. I just tape up the right hand plug for corrision control.
The Left Hand Lid Lock has that Magnetic Reed Relay to signal the Control Board the Lid is Open "OP" or "OD" when the Control Board does not see the lid open after three completed cycles.
Do you think the lid is warped and the Lid lock latches can't seat into the notches in the lid? If they overshoot into the notches that will cause lid lock issue also.
lid lock assembly look for forum response by dh1200s.
You are going to need a complete L.H. Lid lock assembly. p/n 25001048 Google for best price.
You have the issue of the Lid Locks no releasing so even after a replacemant L.H. Lid lock assembly (not cheap) you have the root cause issue to troubleshoot.
If you want to troubleshoot Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
It's free because my time is free. I post as dh1200s at that forum and others as well as here. FAV6800AWDIY is my second account on this forum......Good Luck
Go to the 5th post down there is a link to the Service Manual. The Service Manual will show you how to get into Service Manual and unlock the lid Locks. If you can't unlock in Service Mode the Service Manual will show you how to release the washer top from thew base to remove your clothes.
If you need additional help post in that forum for help ; Maytag/Magic Chef/Admiral/Jenn-Air
Google this ""Sticky: Neptune TL Washer FAV6800AWW""
I have repair notes to help you Troubleshoot and DIY the repair. 5 or 6 post down in the sticky you will find info to help you. This site is terrible for DIY folks. You have lost signaling thru the Left Hand Lid Lock to the Control Board.
There is a link to the Service manual in that Sticky. If you need additional help I will jump in............D*ick
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you. Google this Neptune TL Washer FAV6800AWW This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site. In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine. In that Sticky are other what I find to be common Service Repair notes for issues with the machine. If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
