Brother LS-1217 Mechanical Sewing Machine Logo
Posted on Sep 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought a new belt for my brother VX950 sewing machine and need to know how to adjust the tension so the belt isn't so tight. it's the belt that goes to the motor
Anonymous
Level 3:
Genius:
  • Master 1,788 Answers
  • Posted on Sep 12, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1788
Questions
Helped
361996
Points
4093
Call Brother at 1-877-276-8437 and see if theycan guide you or else you can mess up the timing and everything. Unless you know what you are doing, it is a job for a professional
2answers
Why does bobbin make thread bunch up
needle thread tension not tight enough to pull bobbin thread up into the material
1helpful
7answers
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
1helpful
I have a VX1250. I don't know how to regulate the tension.
There is two places to adjust thread tension: the top tension device controls the top thread tension and is usually a dial or knob with numbers on the front of the machine.
Then there is some form of tension device on the bobbin; in your case I believe the Brother has a removable bobbin case with a tension spring which holds the bobbin thread firmly: the tension spring can be adjusted with a screwdriver but once set, you shouldn't need to adjust this much, just alter the top tension slightly for different weights of fabric. So start by setting top tension dial to 4-5 and test stitch a seam. Use different coloured but the same type of thread top and bottom and take a look at the seam. You want to see a balanced even seam.
Here is a link to a great info site for this:
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If the bobbin thread is too loose, then you probably will need to finess the tension spring on the bobbin case and adjust this slightly. The best way to set the tension on the bobbin case is as follows. Load the bobbin into the bobbin case and pull the thread tail into the tension spring, then suspend the bobbin by holding the thread tail up in the air (the dangle test). You want it to be just tight enough to hold its own weight, but still able to release thread when you pull gently downwards on the bobbin case. If it isn't doing this then take your little screw driver and adjust the screw on the leaf tension spring by ONE QUARTER TURN ONLY. Lefty looser, Righter Tighter. Then test again, and adjust again until its right.
Now test stitch again and finess your top tension to get the seam even. Remember to change the needle for each new sewing project too; this will impact tension also.
1helpful
Brother MB 2600
You should not have to adjust the bottom tension when using sewing thread.
There is a tiny screw on the side of the bobbin case - left/loose; right/tight.
Mark the screw head slot and edge of the bobbin case with nail polish or sharpie so you know where you started.
If you are having a stitching problem that appears to be loose bobbin thread, it may be that the machine was threaded with the presser foot down.
Always thread a sewing machine with the presser foot up.
When the presser foot is down when threading, the thread cannot enter the tension control and you get loose, loopy stitching.
My brother sewing machine is new and I've checked that it is threaded up correctly but the top tension is way too tight, no matter how I change it. Is there no way to change the bottom tension? It is an...
Yes. Open the bobbin and u will see a screw pressing down a metal sheet, which is actually a spring.
This is meant for adjusting the top tension. Loosen this screw by quarter or half a turn and see if it is giving the desired result. You may have to try a few settings before you arrive at the even top and bottom tensions when your thread tension adjustment scale is midway position.
Please note that you adjust the thread tension on the machine to adjust the bottom tension(not the top) .
Please let me know if this solved the problem.
2answers
Belt came off
well that is very nice idea you can fix with your self provide talls most commonly use.Set of screw driver,open and socket wrench,pliers etc...Remove the top cover plate by loosening bolt holding the cover and cover besides the handwheel where the motor was installed besure it was unplug from ac source(No power)Check the motor holder that attaching from casing.You can see the motor coupled by the belt.In the motor holder there is a bolt slot adjustment for tensioning belt tighning and loosening.If you want to disconnect the belt and replaced loosen the tension and pull out the belt.Sometime belt are sliping to the pulley it affect
the sewing machine operation,you can tighten from adjusting the tension of the belt.adjust not so tight after adjusting try to run manually first by turning handwheel freely if the motor will run freely with out obtruction no power supply.If your satiesfied try to run with power supply but jag twice first to be sure no problem occured before continous operation.
1helpful
Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
4helpful
Unable to adjust tension,
Sounds like the bobbin thread is not inside the tension on the bobbin case. This normally happens when the bobbin is upside down. Insert the bobbin and pull on the thread.The bobbin should turn counter clockwise.
sewman7
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
