My power led connector (green,white) power sw connector (black,white) got out of place and i dont where they go
The eMachines T3302 desktop computer, uses an FIC K8M-800M motherboard.
(First international Computer, Inc.)
Where those wires go on the motherboard, is termed a Front panel header.
The Front Panel is the plastic front bezel of your computer.
(Where the Power On button is, Power On LED light, and so on)
Looking at the motherboard with the Processor to the Top, Ram Memory slots to the Right, the Front Panel header is at the bottom right corner, and over to the left.
Look at the jumper block in the bottom right corner. Right in the corner.
This is the LED type selector, jumper block.
Has 6 pins.
3 across the Top, 3 across the Bottom.
(This jumper block is to set whether you are using a Power On LED light, that has Dual Colors, or a Single color.
The default setting of the jumper on the block, is set to use a Dual Color LED light, for the Power On LED)
Move to the left of this jumper block. The Front Panel header is to the left of this jumper block.
(FIC terms it a Front Panel Block Connector)
It should be White in color.
Is right against the bottom edge of the motherboard. (Parallel to the outside edge of the motherboard)
Has two rows of pins sticking up.
5 across the Top.
4 across the Bottom.
The pins are numbered from the Right, going towards the Left.
(From the Power On LED jumper block, towards the Front Panel header)
On the Top row going from Right, towards the Left,
Pins 1 ,3, 5, 7, and 9.
On the Bottom row going from the Right, towards the Left,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the Power On LED light.
Pin 1 is for the Positive ( + ) wire.
(Green)
B) Pins 5 and 7 are for the Power On switch.
Pin 5 is for the Positive ( + ) wire.
(Black)
[Although it really doesn't matter which way the wires go. It's a SWITCH]
C) Pins 2 and 4 are for the HarDDrive activity LED.
Pin 2 is for the Positive wire ( + )
D) Pins 6 and 8 are for the Reset switch.
(IF used)
If any of your LED lights are dim, after attaching the Positive wire for each LED, it's because the Positive wire is on the wrong pin.
Switch the wires around
Also, see if the Blue, and Black pair of twisted wires has a small tag on it/them. Look for HDD. HarDDrive. Believe Black ,and White twisted pair of wires, are for the Power On switch. If you cannot see where they end in the Front Panel, (Front Bezel), then remove the Front Panel, follow the twisted pair of wires up to the Power On switch. (Behind the plastic Power On button) Also, follow the twisted pair of wires that come out of the HarDDrive activity LED, in the Front Panel.
