GLWS1649A - we had a drop in water pressure. first it wouldn't drain or spin. you could force it by resetting the load size and manually forwarding the cyle knob. Pressure is back up, but now it won't agitate when it's filled. It's making a running noise, but won't agitate. you can move the tube by hand though. help
Hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded.
It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall.
Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
SOURCE: Washer will not spin
My mum had this problem. I think it had something to do with the barrel coming loose.. - get a plummer ;)
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
SOURCE: frigidaire washer model FWX833AS1 top load
Hello Lcl2610.
welcome to Fixya,
My name is Huuum,
How old is your machine?
I have found some reasons of what may be the matter!
List of thinks to check
1.Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
2.Faulty Direct Drive Coupling
The
Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore
brands washing machines utilize a small, relatively inexpensive direct
drive motor coupling. It's plastic and rubber and is mounted to the
shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
3. Faulty Water Level Switch
If the water level
switch is not resetting once the water is drain, power will not be
available to operate the motor during spin. Check the water level
4.Will not drain and displays F/02
The error code F/02 will
be displayed if the drain time exceeds 8 minutes. Press pause/cancel
twice to remove display. Check the pump filter and wiring connections
on the pump. If all looks good, replace the pump.
You may want to use a pro, rather than attempt this project your self.
Let me know how it goes!
Thank you Huuum.
Please remember to leave a rating
SOURCE: frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Hi slogjlog - Often when a unit does not spin or agitate, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
