Whirlpool Washer LSR7233BQ2 Buzzes/Humms during...
this is a direct drive,no belts,good washer you won't find any washers built like this anymore,on top console pop off the clips on each side,then remove the two phillips screws,lift the top console,with a regular screw driver stick in into the hole where the clip goes into frame and on top of the clip and push forwards and the clip will pop out,then there's a lid switch a white wire connector on the right top,unplug it,now grab the cabinet and tilt it up and pull back and remove the cabinet.if the motor is humming and it's not draining it sounds like some thing is stuck in the pump or a bad pump,look down and you'll see the pump on the front of the motor,with a screw driver pop off the two clips and slide the pump off,get a piece of wire and stick it into the white connector where you disconnected the lid switch from,this will jump out the switch,set the timer to spin and run it,if the motor spins then you know the pump is jammed or bad.let me know what you find.the pump part is WP3363394
10/7/2017 5:30:17 PM •
Whirlpool...
Answered
on Oct 07, 2017
