Kodak EasyShare V1003 Digital Camera Logo
Posted on May 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LCD screen stopped working
When camera on, LCD screen is blank/white with some vertical moving stripes at bottom. Can not view scene camera is aimed at. What is wrong with it?
SHARCNET-USA
Level 3:
  • Master 2,130 Answers
  • Posted on May 16, 2008
SHARCNET-USA
Master
Level 3:
Answers
2130
Questions
Helped
782539
Points
4950
Does the camera take good pictures? Have you tried downloading them into a PC? If the pictures look OK on the PC but not on your camera's LCD screen, then the LCD screen is most likely defective.
Please read this article that I wrote regarding LCD screen replacement.
http://www.fixya.com/support/r370257-replace_defective_lcd_screen_in_kodak
Lumix DMCTZ2 Problems
DFid you try to shoot a picture, even not seeing what you are shooting? Try it. Then ale check what happens if you press the display button, (left one under the Menu / set buttons)
Let me know how you and your camera are doing now.
Jul 07, 2014 • Cameras
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
1helpful
Problem with my Nikon Coolpix 5700.
Hi there, its a problem of the lens sensor, So i suggest you please contact with you service center. Thanks.
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
White screen.
You may want to ask a guy in South Carolina that has all the used parts for your TZ3. I think his email is [email protected]
Samsung Digital Cam SCD6040 sound problem
I HAVE A SAMSUNG MINI DV DIGITAL CAMCORDER MODEL SC-D353 NTSC.
THE LCD SCREEN IS NOT DISPLAYING. ONLY A WHITE SCREEN WITH VERTICAL STRIPES.
NO PICTURE DISPLAY IN 'CAMERA' MODE OR 'PLAYER' MODE. BUT THE VIEW FINDER IS WORKING.
DO NOT KNOW WHAT IS THE PROBLEM?
HAS LCD SCREEN GONE BAD. IF SO WHO DO I CONTACT. I LIVE IN SILVER SPRING MARYLAND USA
PLEASE HELP
LAKSHMI SHYAMSUNDER
EMAIL: lshyamsunder @ yahoo.com
Tel # 301-649-1371
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
