Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
hi can you give me model numbers off the rider mower and the deck size in inches and its color ( especially if its stx 38 ) and wether side delivery or rear catching or mulching type deck should be numbers on a white sticker on the side of tractor somwhere or under the seat example molstx38##### i will try help you with diagram and or website for parts and diagram that you can access with own user id and p/w cheers let me know numbers and model etc
