Apple eMac G4 Desktop Logo
Posted on Apr 28, 2008
E mac computer
I have a e mac computer/ problem when i turn it on all it shows is a small file on the middle of the screen and i can't click on or nothing what is wrong is it a virus?
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on May 05, 2008
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
10660
Points
33
Is it a file or Folder on the screen?
Are you booting in OS9 or OSX?
Simple answer without knowing the answer to the above questions could be the hard drive is bad. Try rebooting with the install cd's that came with the machine. If you see a disk image it is good if not it is bad. If in Os9 it is a corrupted system folder and that could mean many issues have occurred.
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
2helpful
2answers
Help
Hello, The blinking file folder with the question mark can happen when the computer doesn't "see" your System. It can be caused by a faulty hard drive, or by a damaged operating system. You can try to reboot the Mac, and hold the "C" key with your installation disc in. Select english, the go to the tools menu, and Disk Utility. Go to the SOS tab, select your drive and click "repair". If something red appears, it means that it has found something wrong on your hard drive. Best regards
1helpful
I turn on my mac and only this small folder icon appears in the middle of the screen
The face is probably frowning.  The computer cannot find the operating system.  Use a utility disk to boot up the computer and then use First Aid or Disk Utility to check the disk.  You may have to re-install the operating system.  This can be done without losing your files if done correctly.  Seek help from an Apple repair facility if you are in doubt about how to do it.
3helpful
Powerbook G4 wont start up, shows a file folder with a ? mark....
The hard drive is probably on it's way out. You can get and run Disk Warrior and you could repair permissions and such but the hard drive is probably on it's way to the grave.
A couple things though. It isn't enough to just put the disk in, you need to hold down "c" while the computer starts for it to try to run off your disk. You can then try to repair permissions and fix the disk from the installation program that starts. When the Install OS X screen comes up (looks like a desktop but with the big dialog box in the middle) click on Utilities at the top and then on Disk Utility. HERE IS APPLE'S SITE for you to read about how to try to repair your disk. I've found that this sometimes works and may help it work enough for you to get your files off, but may not.
Another method would be to get another Mac, and hook the two together with a firewire to transfer your files, then reinstall OS X in your ailing computer. Go HERE to read about this technique.
Need to upgrade my mac
locate & click the apple (top left part of your screen)
on the drop down menu, click on "About This Mac"
a small window showing information about your computer & a button that says "Upgrade"
When turns on shows a computer screen and red cross
Hi there
This happens because files on your card are corrupted after an unsuccessful download.
If you have a card backup at hand, put the card into a computer, format it , and restore backup.
After that the TOMTOM will restart working normally.
If you did not make a copy or backup of the original card, or you cannot reach the computer hosting the last backup.Then follow the procedure below to restore your data :
1. Uninstall the application
2. Reinstall the application
attention_25.gif We highly recommend backing up your device before continuing. questionmark_25.gif
This will preserve any maps and voices you may have purchased.
1. Connect your device to your computer.
2. Go to Computer (Vista), My Computer (XP) or your Desktop (Mac).
3. Double-click the TomTom disk drive to open your TomTom.
4. Make sure that hidden folders and files are shown. To do this:
  • Vista: Go to Organize > Folder and Search Options, click on the View tab and select the option Show hidden files and folders.
  • XP: Tools > Folder Options..., click on the View tab and select the option Show hidden files and folders.
  • Mac: With the exception of some system files, your Mac should already show all hidden files and folders on the TomTom drive.
5. Identify the map folders on the TomTom. These are named for countries or regions such as USA_and_Canada, North_America or any other country or geographical region.
6. Delete all files EXCEPT these map folder(s) and the folder titled ASR, if it exists (the ASR folder will not appear on every device).
7. Properly disconnect the TomTom from the computer and exit TomTom HOME, if it is open.
  • Vista/XP: Right-click the TomTom drive and choose Eject.
  • Mac: Drag the TomTom drive to your Trash.
8. When the TomTom boots you should see a screen with the flashing X.
Proceed to reinstall the application (below):
My mac won't start up
try re-installing the software.
looks like OS is already corrupted.
you can also call 1-800-my-apple for more help.
2answers
APPLE MAC POWERBOOK G4 LAPTOP COMPUTER
It sounds like your system is trying to boot from a network.
Insert your installation CD/DVD restart your computer holding down the 'c' key, this will allow it to boot from the CD/DVD, you should be now able to select your start up drive, select it then either follow the prompts or restart again
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
