20 Most Recent Apple eMac G4 Desktop Questions & Answers
Why is there no display on my Apple eMac G4 desktop?
Have you tried turning it on and off again?
3/6/2015 12:57:51 PM • Apple eMac G4... • Answered on Mar 06, 2015
2answers
I have a question can i instal two pc moniters to
I have 2 monitor. 1.) Apple Monitor 2.) dell monitr You just need the Graphic card added . i got mine from a old Mac
2/6/2015 9:21:01 PM • Apple eMac G4... • Answered on Feb 06, 2015
Why does my emac eject all cds and dvds?
time to replace it. Check to see if eject key is stuck.
7/28/2014 8:54:58 PM • Apple eMac G4... • Answered on Jul 28, 2014
2answers
I was using this computer until about an hour ago. Now it asks for a password and won't unlock the screen.
I called the product's support services, and was instructed on how to unlock, and boot up my eMac G4 1.0, OS X version without a startup disk. There are also several safe, and legal sites online that can assist you, with your current issue, hotspot wifi installing plus many other questions, and needs. Hope this info has been helpful in any way, and thank's for asking !
6/1/2014 2:14:24 AM • Apple eMac G4... • Answered on Jun 01, 2014
Forgot user password
Hi I'm Peter , You can change your user password by going in with your administrator password. Here are a few helps https://iforgot.apple.com/password/verify/appleid and see http://support.apple.com/kb/HT1274 and
and Kappys answer https://discussions.apple.com/thread/4251616?start=0&tstart=0
In OS X Lion or later, you can reset your user password with your Apple ID.
In Mac OS X v10.6.8 or earlier, follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu. Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu. Mac OS X v10.3: Choose Reset Password from the Installer menu. Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet. Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account. Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account. http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1274/HT1274_Leopard.png
  6. Hope this helps.
4/20/2014 3:55:14 AM • Apple eMac G4... • Answered on Apr 20, 2014
Needs a by pass log in code
You need the system disk for that machine. Start up from the disk and run 'Rest Password' from the 'Utilities' menu.
4/9/2014 4:03:31 PM • Apple eMac G4... • Answered on Apr 09, 2014
I get the flashing question mark but when I
Hard drive failure. Your Mac cannot find a bootable OS.
12/26/2013 11:48:18 PM • Apple eMac G4... • Answered on Dec 26, 2013
How to remove a tilt/swivel base from an eMac?
Hi Robert. Remove all connections from your E-mac including powercord. Put a folded blanket on the floor and lift the E-mac from the table and put it on the folded blanket so that the screen is on the blanket. Now you have acces to the bottom. Unscrew and take the swivel off. Be careful because eMac is the heaviest computer ever made by Apple. Good luck.
12/7/2013 3:14:44 PM • Apple eMac G4... • Answered on Dec 07, 2013
manual
How to rightfully, reset an admin's password at start up log in.
If you know the current administrator password, you can change it by going to System Preferences: Accounts.If you've lost the password, you need Disk 1 of the OS install disk set. Start up the computer and put the disk in the optical drive. Restart the computer and hold down the option key immediately after the chime until a disk icon appears on the display. Wait a few seconds more until the optical disk icon appears. Click on this, then on the arrow to boot up from the install disk.When the OS installer appears, go to the Reset Password... item in the Apple menu and follow the directions there. (Select the administrator account from the pull-down menu.) If your install disk is not specifically for an eMac, or is made for an eMac with a different graphics chip, the display quality may be poor, but you should still be able to pick out what you need to see from the Password applet.
6/27/2013 5:16:18 AM • Apple eMac G4... • Answered on Jun 27, 2013
Mac isnt loading
If you're getting the blinking no folder icon, then the hard drive either needs to be re-seated or is dead. If you're not getting any power, then you'll need to troubleshoot the cable and power routes.
12/12/2012 1:44:59 AM • Apple eMac G4... • Answered on Dec 12, 2012
2answers
Slow running mac
There are a number of reasons that may causing a Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more the solution here: http://www.howtospeedupmac.com/
6/22/2012 2:46:55 PM • Apple eMac G4... • Answered on Jun 22, 2012
2answers
My emac doesn't power on
unplug it over night and try to power up in the morning
5/28/2012 9:09:49 PM • Apple eMac G4... • Answered on May 28, 2012
Manual for emac 1 ghz power pc
Best place is eBay for parts but you can find all sorts of manuals with Google.
2/15/2012 11:41:01 PM • Apple eMac G4... • Answered on Feb 15, 2012
Operating system was deleted on my emac a1002. i
You should have a set of DVDs woth the operating sustem on them - they are included when you buy a Mac.If you don't have them then you will have to buy some on either eBay or from Apple's on-line store.
11/16/2011 1:07:36 AM • Apple eMac G4... • Answered on Nov 16, 2011
I have emac 10.2.8 with
Hi SardaIn order to upgrade your Safari you need to upgrade your OS to 10.4.11 at least.Try ebay for a copy. Once you have done that Software Update will automatically offer to update Safari to the latest version applicable.It's not the machine - it's the OS that matters.
9/28/2011 7:40:35 PM • Apple eMac G4... • Answered on Sep 28, 2011
Vertical strip flickering and pale
check with external display to if there is same problem if it. Its your hardware problem.
9/26/2011 6:46:22 AM • Apple eMac G4... • Answered on Sep 26, 2011
Flashing "?" when starting macbook..i
Can you be clear on the question:- 1>How did you try to Install disk start up. 2> is your harddisk been shown on Disk utility 3> are you using the right media for the same.
9/21/2011 12:20:28 AM • Apple eMac G4... • Answered on Sep 21, 2011
My Emac will not start up. It makes a high pitch
Put your system disk and power up holding down the c key on your keyboard. Once booted up go to the file menu and go to disk utility once open see if your hard drive is showing up. If it does run verify disk to to check whether your hard drive needs repaired if it does run the repair disk on it. That should get it up and running. However if your hard drive does not show up it is possible that the hard drive has failed. You would then need to replace the hard drive. Hope this helps.
8/21/2011 11:07:38 PM • Apple eMac G4... • Answered on Aug 21, 2011
I have a emac powerpc
If you hold down the mouse button, and then turn on the eMac, the drive will pop out, and you can put in a CD. Also, you can hold the F12 button to eject. Even if there isn't a dedicated Eject key on the keyboard, you can eject this way.
8/19/2011 12:55:36 AM • Apple eMac G4... • Answered on Aug 19, 2011
Apple eMac G4 Desktop Logo
140 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
using computer until about hour ago now
  • Computers & Internet
