20 Most Recent Apple PowerBook G4 Mac Notebook Questions & Answers
2answers
Can I use a password reset disk to change the password on a powerbook g4?
Your absolute best bet is to re-install the system operation system.OS 10.5 is your brts bet. then follow the instructions and answer all of the needed information. Because I live alone and my computer is never out of my personal living area, I never instal a password. But this is your choice also.
7/25/2021 1:06:51 AM • Apple PowerBook... • Answered on Jul 25, 2021
2answers
How do you reboot in safe mode
not really - safe mode is a windows feature - MAc is based on BSD unix
Try holding down the "Shift" key as you boot to keep extensions and control panels from turning on. You get the message saying extensions are off after about ten seconds or so.
10/5/2020 6:56:40 AM • Apple PowerBook... • Answered on Oct 05, 2020
2answers
Cracking regional code setting on my Mac PB G4
Download Region X 1.6. It allows you to freely change the DVD region and it's FREE.
3/4/2020 2:02:57 AM • Apple PowerBook... • Answered on Mar 04, 2020
2answers
DVD Region Code: change on Mac?
Download Region X 1.6. It will let you set the region to whatever you'd like and it's FREE.
Hope this helps.
11/7/2019 8:51:26 AM • Apple PowerBook... • Answered on Nov 07, 2019
2answers
Dvd player
this will do it
power off the g4
power on the g4, then press and keep holding the touchpad button
and also the eject button for about 5 minutes. then it will eject it.
dont use that dvd again. not compatible with your laptop
11/6/2019 9:37:31 AM • Apple PowerBook... • Answered on Nov 06, 2019
My powerbook g4 laptop screen was flickering but now it's just an array of colors but I can not see my desktop files. help
its sounds like either you have a bad display or the wires are loose. if you have a repair shop nearby have them open it up and check to display plug to make sure its firmly in the Motherboard port
9/28/2019 4:16:41 PM • Apple PowerBook... • Answered on Sep 28, 2019
Wont read/write hard drive
use Apple Hardware Test to diagnose the error::
1 Disconnect all external devices from your computer except the power adapter.
If you have an Ethernet cable connected, disconnect it.
2 Insert the Mac OS X Install Disc 1 that came with your computer.
3 Restart your computer and hold down the Option key as it starts up. A list of available
startup volumes appears. Click Apple Hardware Test and click the right arrow.
4 When the Apple Hardware Test main screen appears after about 45 seconds, follow the
onscreen instructions.
5 If Apple Hardware Test detects a problem, it displays an error code. Make a note of the
error code before pursuing support options. If Apple Hardware Test does not detect a
hardware failure, the problem may be software related.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
8/1/2018 1:08:05 PM • Apple PowerBook... • Answered on Aug 01, 2018
2answers
I have a 2002 Mac PowerBook G4 trying to connect via Ethernet .plugins are all on the back of Mac don't seem to be any tutorials ,I am connected to house wifi hub (ntl)can any one help me
Call Apple MacBook Pro technical support phone number 1-800-204-4427 for repair Apple MacBook Pro & upgrade MacBook Pro storage. Troubleshoot ... 1 8002044427 Apple MacBook Technical Support Phone Number Mac Help
12/8/2017 11:59:30 AM • Apple PowerBook... • Answered on Dec 08, 2017
Black screen no fan sound but apparently getting power
for solve any type of error and issues dial toll free number +1(800)726-0294 and for more visit - 1 800 726 0294 Apple Support Number Mac Technical Support Help
9/18/2017 9:39:16 AM • Apple PowerBook... • Answered on Sep 18, 2017
Lost power when changing computer name and key. no boot or sys disk. boots to apple logo and spin wheel. how to recover w/o loss of data
Try holding down the option key (ALT) when you boot up and see if you can see your startup disk. Good luck....
6/8/2016 4:05:27 PM • Apple PowerBook... • Answered on Jun 08, 2016
White screen and small question mark inside a folder
This means that the operating system cannot find the file system. Generally this is a sign that the hard drive has failed. The first thing I would try would be to boot from the OS X install disc and see if it can locate the drive to reinstall the operating system. If it can, you may be able to fix it that way. If it can't, likely the drive has failed and needs to be replaced. FYI if the drive is 'almost' failed, I have had success with taking it out and putting it in the freezer for a few hours, then back into the computer. It may work for long enough to allow you to back up anything you are missing.
3/18/2016 2:15:25 AM • Apple PowerBook... • Answered on Mar 18, 2016
How do i factory reset a powerbook g4 so it has no password blocking it.or how do i get into the computer.
Are you asking how to unlock a computer that is password protected without the password? You cannot do this, that is the whole point of security. You could manually wipe the entire hard drive using another device, then reinstall the OS on it from another Mac, but then all the data would likely be lost.
3/14/2016 3:55:28 PM • Apple PowerBook... • Answered on Mar 14, 2016
2answers
How replace backlight mac?
The reasons for backlight situation are; 1 bad screen 2. backlight chip being defective on the logic board 3. bad inverter. It is therefore advised to take your machine to a local mac repair store. Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
5/19/2015 6:12:23 AM • Apple PowerBook... • Answered on May 19, 2015
Lg smart tv
G$ powerbook will have a high-density video connector providing (usually) VGA and DVI, All you have to do is to choose the relevant adapter and connect the two units together with a suitable lead.
3/8/2015 11:29:58 AM • Apple PowerBook... • Answered on Mar 08, 2015
I don't know how to connect an external modem to my PowerBook G4 12
You need an Apple modem. https://www.google.co.uk/search?q=apple+usb+modem&espvd=2&source=lnms&tbm=shop&sa=X&ei=SyT2VN7mE9KXavCJgng&ved=0CAcQ_AUoAQ&biw=1920&bih=971
3/3/2015 9:15:22 PM • Apple PowerBook... • Answered on Mar 03, 2015
How to do a factory reset on ibook M6497
Warning: Resetting the Power Manager on any PowerBook or iBook will permanently remove a RAM disk, if present, and all of its contents.
  1. If the computer is on, turn it off.
  2. Disconnect the AC power adapter.
  3. Remove the battery.
  4. Press and release the reset button (shown here) located above the Audio/Video port on the left side of the iBook (Dual USB) computer by inserting the end of a paper clip into the small hole and gently pressing the switch once.
  5. Wait 5 seconds.
  6. Reconnect the AC power adapter.
  7. Put the battery back in the computer.
  8. Press the Power button to restart the iBook computer.
12/31/2014 8:42:27 PM • Apple PowerBook... • Answered on Dec 31, 2014
Download skype
12/11/2014 6:11:02 PM • Apple PowerBook... • Answered on Dec 11, 2014
2answers
I dont know how to
go into system preferences and goto startup disk and click on Mac OS X 10.X.X
9/29/2014 9:08:22 PM • Apple PowerBook... • Answered on Sep 29, 2014
Apple PowerBook G4 Mac Notebook Logo
392 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
G4 Apple
  • G4 Apple
Most Popular Question
find itunes 9
  • Computers & Internet
