SOURCE: delay print
I found the answer to this situation: To turn off delay print function, Push the print mode button on the upper right hand control keyboard.
Thanks for the help!
Kathy
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
SOURCE: When I type letters, some of them turn to numbers
Numlock is turned on, press the FN button on lower left and look for the numlock key, you should see numbers 1-9 on the keys that you have been pressing, those buttons have numbers and the letters, just turn the numlock off, and they will be letters again.
SOURCE: My laptop keyboard types two letters at a time.
I am convinced. If the situation were not serious I would say that you invented a new language.
It seems that the letters concerned are aligned in two columns. Possible that the wires are not well electrically isolated. I would suggest you try to clean the keyboard with a soft brush or compressed air. If that does work you should have the keyboard repaired.Was some electolytic liquid (salt water, orange juice) spilled on the keyboard by any chance?
Hope it helps.
