Panasonic Lumix DMC-LZ2 Digital Camera Logo
Posted on Jul 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My daughter dropped my lumix at camp, now the lens will not retract and the camera can not focus. Is it worth attempting to get repaired or should I just buy a new one?
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Jul 30, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1184379
Points
12747
TRY THIS FIRST
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help++++ to keep the service online
Any one there able to help? URGENTLY NEEDED SERVICE (REPAIR) MANUAL FOR PANASONIC LUMIX LF-1
It won't be easy to get a repair manual. But I advice to visit ifixit, to see if they have a manual or video for your camera. They also can help with spare parts. Camera Repair
Nov 15, 2014 • Cameras
1helpful
Camera lens will not retract - sistem error (focus)
Lens errors (system errors on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
1helpful
I have an FS15 and get the error message, 'system error zoom' the lens is not centred and does not retract. The camera has not been dropped and is c15m old.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Stuck lens on on lumix dmc-LX2
u could go to best buy but it might be cheaper to buy a new camera
The lens want close due to being bent
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
3helpful
Lens won't come out after dropping camera.
Only lightly toasted. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. There is no safe DIY fix for either condition, but the camera can be repaired by the manufacturer or at a local camera shop. Make sure to get an estimate first -- you may need to decide if the camera is worth the cost of the repair.
Dropped camera which landed on zoom lens.
Have you tried manually trying to pull out the part that is pushed in?
3answers
Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
3helpful
2answers
Camera focus error
there is a small logic circuit that controls the motor that retracts the lens and a sensor that tells it the lens is retracted, it is a lens position sensor, one of these two components is most likely defective, the thing is there are no consumer service info provided by panasonic, they will not sell you parts either, the camera is a mystery to take apart and repair without the tech manual which u can't get, so u see the delima here, u must either have this camera fixed by a panasonic repair station or see if it qualifies for a upgrade exchange program for a newer model.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
