20 Most Recent Panasonic Lumix DMC-LX2 Digital Camera Questions & Answers
Why does camera shut down?
Your batteries are no good! Digital cameras need a good amount of current to operate and when they are not fed properly they will just shut down!
11/24/2015 1:19:15 AM • Panasonic Lumix ... • Answered on Nov 24, 2015
There are horizontal stripes of blur when I take pictures, then pictures save fine on computer, but when I want to edit them they come up damaged.
Your micro sd card may be damaged. You can reformate your sd card on your computer or get a new one.
2/2/2015 5:55:33 AM • Panasonic Lumix ... • Answered on Feb 02, 2015
2answers
Hi - i have a Lumix DMC-LX2 that has just recently
sounds like the button or direction joystick is making continuous contact. You could try using canned air on it to blow it out. Otherwise i would get it professionally cleaned. Nice camera by the way.
9/28/2014 6:16:12 PM • Panasonic Lumix ... • Answered on Sep 28, 2014
Broken screen on panasonic lumix DMC-LX2. Have repair???
Hello I got one with broken lens (grinding cogs) : otherwise P'fect could we organise something ?Pete Cooper.
12/25/2012 10:40:32 AM • Panasonic Lumix ... • Answered on Dec 25, 2012
I have a gifted panasonic lumix DMC-LX2 but the settings is in french.How do i change the language to english
Press the MENU/SET button. Press cursor-left. Use cursor-up/down to select the wrench icon and press cursor-right. Use cursor-up/down to select the talking-head icon. Use cursor-up/down to select the desired language and press MENU/SET.
6/27/2012 7:11:08 PM • Panasonic Lumix ... • Answered on Jun 27, 2012
Lens stuck on our LX2 again, had it repaired first
Go to this website and try the solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
10/24/2011 4:06:21 PM • Panasonic Lumix ... • Answered on Oct 24, 2011
MY CAMERA READS THIS MEMORY
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
8/8/2011 7:26:12 PM • Panasonic Lumix ... • Answered on Aug 08, 2011
When I turn it on,
If you are traveling and do not have access to a vacuum to pull the dirt out the next best thing would be to try to blow it out with a can of the compressed air....like you would use for a keyboard to clean it.
The problem is most likely just dirt stuck in the lens...
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
6/6/2011 12:05:32 PM • Panasonic Lumix ... • Answered on Jun 06, 2011
2answers
HI, IS THERE A SOFTWARE DOWNLOAD TO TRANSFER
May I suggest something easier? You can just get a memory card reader, attached the memory card inside and then connect to your computer. You can upload the photos to your computer without the need to download extra software. Plus, it will save the battery of your camera.
3/7/2011 5:10:26 AM • Panasonic Lumix ... • Answered on Mar 07, 2011
2answers
How do I remove the front casing from my Panasonic
Digital cameras are constructed to be disassembled from the rear of the camera. Therefore, to get to the lens assembly or other part, it must be taken apart from the rear, and totally disassembled. If you're having a problem with the lens, there is a web page that suggests things to try before opening up the camera or having it serviced:
Good luck, and hope this helps.
1/1/2011 9:00:40 PM • Panasonic Lumix ... • Answered on Jan 01, 2011
Just finished charging the battery
Hello....I have the same issue with my Panasonic Lumix DMC-FS5 camera we bought 3 years ago. All of a sudden the camera doesn't work. I have had many cameras and I have never seen this before. I will think twice about buying a panasonic again.
12/12/2010 3:37:45 PM • Panasonic Lumix ... • Answered on Dec 12, 2010
I dropped my lumix dmc-lx2
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
11/29/2010 11:25:02 PM • Panasonic Lumix ... • Answered on Nov 29, 2010
2answers
LX2 Switch on, lens extends,screen
Have you taken the camera outdoor lately? This problem is most probably caused by a grit of sand or dust build up between the camera's base and the lens' barrel, hence it wont retract and the camera malfunctions. What you do is to hold the camera with your right hand with its lens facing the ground. Then tap the camera's base to your left palm as you push the ON button of the camera with the intention of removing that grit out of the len's barrel. You might have to do this several times.
9/2/2010 4:11:39 AM • Panasonic Lumix ... • Answered on Sep 02, 2010
I have an SD 4GB card which I used to use for my
When the error comes up onscreen you should still be able to access the review menu (where you look at your photos), just keep pressing the button for review. even though the error shows you should definitely still be able to format it in camera. Also double check the usual things - the card is unlocked and compatible with the LX2. Hope that helps.
7/25/2010 7:51:22 AM • Panasonic Lumix ... • Answered on Jul 25, 2010
This memory card is protected
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
3/9/2010 6:54:30 AM • Panasonic Lumix ... • Answered on Mar 09, 2010
Stuck lens on on lumix dmc-LX2
u could go to best buy but it might be cheaper to buy a new camera
1/13/2010 2:42:28 PM • Panasonic Lumix ... • Answered on Jan 13, 2010
I have a Lumix DMC-LX2. Display message close and reopoen camera.
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
12/10/2009 9:46:27 PM • Panasonic Lumix ... • Answered on Dec 10, 2009
2answers
Lumix dmc lx2
Does the menu show up on the screen, or is it totally black?
Does the camera take pictures and behaves as normal (apart from black screen ;)?
If the menu shows up then I'm afraid it's most probably something serious- like dead CCD or failed shutter (probably the latter-LX2s are not famous for failing CCDs). Failed shutter is easy to identify. You would normally hear a faint mechanical"click" when taking a picture (make sure you disable sounds in your camera). If you can't hear anything then the shutter might be dead. In cases like this I normally suggest getting a donor camera from ebay and replacing the lens (the shutter assembly is inside the lens but it's much easier to replace the whole lens).
Good luck,
Raf
11/5/2009 5:16:46 AM • Panasonic Lumix ... • Answered on Nov 05, 2009
Panasonic Lumix  DMC-LX2 Digital Camera Logo
35 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
gifted panasonic lumix dmc lx2 but
  • Cameras
