20 Most Recent Panasonic Lumix DMC-FZ7 Digital Camera Questions & Answers
2answers
My Panasonic Lumix DMC-FZ7 will not read memory
It wants you to format the card in the camera. This will erase the card so download any pictures on it first using a card reader if necessart.
2/17/2018 7:46:22 PM • Panasonic Lumix... • Answered on Feb 17, 2018
0answers
3answers
How do i delete photos from my Lumix camera
For one pic at a time, bring up the pic you want to delete and press the button with the trash can icon. Follow the on-screen instructions. To delete all pictures at once, just go into the menu and find "format"...follow the on-screen instructions.
10/11/2017 8:12:05 AM • Panasonic Lumix... • Answered on Oct 11, 2017
I dropped my brand new panasonic lumix camera in
Take it to a repair facility, you may be lucky.
9/18/2017 8:48:10 AM • Panasonic Lumix... • Answered on Sep 18, 2017
I cannot delete some pictures
If you do a complete format of the card, that should do the deed.
8/31/2017 2:37:27 AM • Panasonic Lumix... • Answered on Aug 31, 2017
Can I use an 8gb memory card in this camera
Do neither the manual nor the manufacturer's site provide this information ?
2/5/2016 1:13:32 AM • Panasonic Lumix... • Answered on Feb 05, 2016
Where can you get the software cd for the Panasonic fz7 digital camera?
See at Panasonic product support: 6 Megapixel Digital Camera with
10/19/2015 9:15:34 PM • Panasonic Lumix... • Answered on Oct 19, 2015
Reset to factory settings - what does 'reset file
"Reset file No." is the reset for the numbering system on your file folders only. You want to use just "Reset" which will reset the entire camera back to factory settings.
10/16/2015 2:37:09 PM • Panasonic Lumix... • Answered on Oct 16, 2015
My computer with windows 7 will not load the photos from the camera, the lumix disc does not include windows 7, any ideas?
Go to Panasonic website support and download the software!
8/16/2015 12:27:11 PM • Panasonic Lumix... • Answered on Aug 16, 2015
Have a LUMIX DMC-FZ7.After downloading some pictures onto my computer there is a reddish demarkation starting at horizon to bottom of picture.It's not visible on camera screen. What is the solution?
looks like it may be ccd problem or loose connection, reset the camera with full charged batteries, light bang the camera with you hand at the base, do this with camera on
6/3/2015 12:47:11 AM • Panasonic Lumix... • Answered on Jun 03, 2015
2answers
Please turn off and then back on again
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from a camera repairer who charges $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the FREE service online ++++Thanks for using FIXYA
3/16/2015 12:49:16 AM • Panasonic Lumix... • Answered on Mar 16, 2015
2answers
Memory caed error please check the card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
12/25/2014 6:01:50 AM • Panasonic Lumix... • Answered on Dec 25, 2014
Camera wont focus
Check to see if AF switch on lens is correctly positioned.
12/24/2014 5:10:37 PM • Panasonic Lumix... • Answered on Dec 24, 2014
Plugin facebook
how do I add follow button on facebook
9/30/2014 11:10:43 PM • Panasonic Lumix... • Answered on Sep 30, 2014
0answers
Panasonic Lumix DMC-FZ7 Digital Camera Logo
300 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
get software cd panasonic fz7 digital
  • Cameras
