20 Most Recent Panasonic Lumix DMC-LZ2 Digital Camera Questions & Answers
Sounds crazy but just make sure yo have removed the lens cover. If it does not work then something is wrong with your Panasonic and i would immediately return it for a another new unit that works properly. You might want to check manual to see if you are doing something wrong but I don't think so.
Panasonic Lumix... | Answered on Aug 28, 2017
I think the technical term is 'ruined'. Cameras are not built to withstand such abuse. Repair is unlikely to be cost-effective, so replacement seems the only option, taking the cost out of the kids' pocket money.
I am curious, though - why on earth did you leave an expensive electronic device anywhere that they could get hold of it ?
Panasonic Lumix... | Answered on Mar 28, 2017
Use an external photo editor and export photos with visual date stamp derived from exif info within file. FastStone Image Viewer Powerful and Intuitive Photo Viewer Editor and...
Panasonic Lumix... | Answered on Aug 04, 2014
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Panasonic Lumix... | Answered on May 28, 2014
There's a small dial on the left side of the viewfinder (next to the flash button) that allows you to focus the viewfinder. I only found it because I had the same problem - must have knocked it out of focus by accident!
Panasonic Lumix... | Answered on Apr 28, 2014
No. The DMC-LZ2 works with MMC and SD cards.
Panasonic Lumix... | Answered on Apr 27, 2014
There is no update for the DMC-LZ2 available If Panasonic has new firmware for any camera, it will contact all registered owners and tell where and how to get and install the update.
Be aware, you only can update a correct working camera. There is no way to update a camera that does not function for 100%
Panasonic Lumix... | Answered on Jan 25, 2014
What type and size memory card are you trying to use? The DMC-LZ2 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Panasonic Lumix... | Answered on Dec 17, 2013
What do you mean by "gets stuck on zoom? Are you getting any type of error message?
Panasonic Lumix... | Answered on Dec 08, 2013
insert the SD card direct into pc is best way
Difficult to find anything, but perhaps you try to download and instal an update of PhotofunSTUDIO via this link?
Not sure you can install this, if you don't have a registration, but perhaps the type and serial number is enough.
Link to PhotofunSTUDIO update.
Panasonic Lumix... | Answered on Nov 17, 2013
Press menu/set...playback menu....select "copy" Make the choice to copy the internal memory to the card and select "yes".
Panasonic Lumix... | Answered on Nov 12, 2013
Panasonic Lumix DMC-LZ2 Digital Camera Logo
393 questions posted
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
panasonic lumix dmc lz2 image melts
  • Cameras
