20 Most Recent Panasonic Lumix DMC-FH1 / DMC-FS10 Digital Camera Questions & Answers
How to download photos from my panasonic lumix DMC - FH1 camera to PC running on windows 10
Put the media card in a card reader attached to your computer.
11/17/2016 11:01:02 AM • Panasonic Lumix... • Answered on Nov 17, 2016
Why isn't my camera reading my SDHC 16GB card anymore when it worked fine the other day ?
There are recovery programs available. Google SDHC data recovery.
3/4/2015 6:47:38 AM • Panasonic Lumix... • Answered on Mar 04, 2015
How to connect camera to pc
Do you really want to connect your camera to your computer? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
4/29/2014 1:59:21 AM • Panasonic Lumix... • Answered on Apr 29, 2014
Lost photofunstudio
Do you really want the Panasonic software when there are so many better alternatives available, such as Picasa (http://picasa.google.com )?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.If you really want Photofunstudio then try http://l.go-for-files.com/j5GjQm7c6U1jxr5WZdbxM2bToSh0tbc4YrG5JnXulj53qNhhEuLPKFO2mjJDvMxaF%2BzHXxSUilYH18VbDdk5RAzZ
11/17/2013 4:05:50 PM • Panasonic Lumix... • Answered on Nov 17, 2013
Long time i didnt use my cam before its working
You can try a new battery or make sure the older one is getting charged by the camera. Remember the camera needs to be in the "OFF" position when you try to charge it.
11/11/2013 3:01:38 PM • Panasonic Lumix... • Answered on Nov 11, 2013
How can i fix my camera because 6months ago i
I'd suggest going to this link for assistance with your camera if you are located in the US.Click Here
10/24/2013 7:38:03 PM • Panasonic Lumix... • Answered on Oct 24, 2013
I have lost the lead from my camera to my computer so I can't get the photos off my camera on to my Mac. Where can I find a replacement lead?
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto.Even if you have to purchase a card reader, you might save money anyway. The last card reader I bought cost me less than the last USB cord I bought (and I still haven't used that cord with any of my cameras, only with my tablet).
10/21/2012 5:43:37 PM • Panasonic Lumix... • Answered on Oct 21, 2012
How do i put my pictures on to my computer i can't find instructions in my booklet
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
9/23/2012 8:20:29 PM • Panasonic Lumix... • Answered on Sep 23, 2012
My Panasonic Lumix DMC-FH1 digital camera will not let me delete photos,
First : is it the same to other SD Card?If yes thenSecond: is it happened to other SD Card?if the second answer is YES -> it might be the I/O part of the camerabut if the second answer is NO -> try to re format that SD Card it might contained a faulty fat (file alocation table)I hope it help
12/29/2011 5:03:32 PM • Panasonic Lumix... • Answered on Dec 29, 2011
Panasonic Lumix dmc fs10
Press Menu / Set button.
Choose the Settings Menu (Wrench Icon)
From there you should find the Lanugage Menu.
10/22/2011 11:05:28 AM • Panasonic Lumix... • Answered on Oct 22, 2011
My Panasonic Lumix FS10 wont
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
9/21/2011 10:20:32 PM • Panasonic Lumix... • Answered on Sep 21, 2011
Panasonic Lumix DMC -FH20 lens
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
8/15/2011 12:53:50 PM • Panasonic Lumix... • Answered on Aug 15, 2011
I have a panasonic lumic
Check out the Panasonic (Netherland) Website.
Hope it helps.
5/22/2011 2:15:24 PM • Panasonic Lumix... • Answered on May 22, 2011
No battery power remains
On my Leica camera when I turn it on no battery power remains appears why is this?
11/23/2022 9:08:59 PM • Panasonic Lumix... • Answered on Nov 23, 2022
Sony camera service centre pakistan
if theres available online seller in your place try ordering online
4/15/2019 10:59:39 AM • Panasonic Lumix... • Answered on Apr 15, 2019
Panasonic Lumix DMC-FH1 / DMC-FS10 Digital Camera Logo
44 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
lost lead from camera computer 39 t
  • Cameras
