1. How can I set Outlook so that it's separate access for my boss and I?
r:/ question: are you both (you and your boss) using the same computer account?, as long as you have outlook installed and if your boss and you are using different accounts you should have separate access to outlook.
2. view his calendar (mirror): usully you would need an exchange server, if you do see if this helps: sorry I have no pics but try to follow the instructions and post back with your questions:
this is assuming you have outlook 2003 In Calendar, in the Navigation Pane (Navigation Pane: The column on the left side of the Outlook window that includes panes such as Shortcuts or Mail and the shortcuts or folders within each pane. Click a folder to show the items in the folder.), click Share My Calendar.
1.
HideI don't see Share My Calendar
Share My Calendar does not appear unless you are using an Exchange Server e-mail account. What is an Exchange Server account? Also, if you have the Navigation Pane turned off or covered by the main Calendar window, you won't see it. Hide or show the Navigation Pane.
2. Do one of the following:
HideAllow anyone to access your Calendar
1. In the Name box, click Default.
2. Under Permissions, in the Permission Level list, click the permission level that you want.
For details about permission levels, see Outlook folder permissions.
You can create custom permissions by selecting the check boxes and options under Permissions.
HideSpecify the people who can access your Calendar
1. Click Add.
2. In the Add Users dialog box, in the Type Name or Select from List box, enter the name of the person whom you want to grant sharing permissions to.
3. Under Add Users, click Add, and then click OK.
4. In the Name box, click the name of the person you just added.
5. Under Permissions, in the Permission Level list, click the permission level that you want.
Important If you select the Private check box on a Calendar item in Microsoft Office Outlook 2003, do not grant Read permission to your Calendar folder to anyone whom you do not want to see private items. A person who is granted Read permission to access your folders could use programmatic methods or other e-mail applications to view the details in a private item.
source:
sharing a calendar in outlooknow if you don't have an exchange server you may need another tool to make this work: like officecalendar, or try to see if the instructions proposed in the following
link work
good luck!
