20 Most Recent Microsoft Office Outlook 2007 for PC Questions & Answers
7answers
MS Outlook pst file overwritten.
Open the pst file in Outlook & see if the conents are still existing.
File -> Open -> Outlook datafile
7/9/2020 4:57:38 AM • Microsoft Office... • Answered on Jul 09, 2020
5answers
Outlook inbox repair
In case of severe corruption of Outlook,while repairing PST file Outlook's inbuilt function Inbox Repair Tool get hang. So in such kind of situations to repair outlook 2007 when inbox repair tool hangs you can use the third party tool like, Inbox repair software. This software helps you to recover all lost data from corrupted PST file. You can download its free trial version and try for recovery.
9/29/2018 5:55:02 AM • Microsoft Office... • Answered on Sep 29, 2018
4answers
Outlook 2007 will not open
Inbox repair tool(scanpst) is the best tool that can be used when you are finding any difficulties to connect your inbox folders or pst files or it is reporting that your Inbox folders or Outlook PST file may be damaged in Microsoft Office Outlook 2000 (or higher).Scanpst is a tiny tool installed by default when installing Microsoft Office 2000 or higher. PST files or Personal Folder Files are used by Microsoft Outlook for storing Outlook data, including mailbox files, email folders, contacts or any other personal data related to Microsoft Outlook. see the step by step instruction here
http://soluzia.net/How-to-repair-Outlook-folders-using-the-Inbox-Repair-Tool.php
5/19/2018 7:20:15 AM • Microsoft Office... • Answered on May 19, 2018
tip
I cannot access my Verizon mail _ Verizon.net server responded: Authentication...
Hi.
The following tip applies to users that want to access Verizon mail using an e-mail managing software as for example Outlook, Outlook Express, Eudora and similar.
The checkup procedure and server settings can also be used to setup your verizon email on a mobile or on a PDA.
If the Verizon server responded: Authentication failed, that means that either your ID, or your password had not been recognized.
Ensure that Caps Lock is not on.
ID and password are case sensitive, ensure that you use capitals only if needed.
Ensure that you entered the right user ID and password for your mail.
The ID must be your Verizon email address, or the first part of the Verizon email address (before @ sign). Password must be your Verizon email password.
If for example the address is [email protected] , then try first putting id [email protected] , if that does not work, try again with MyMail as ID.
The format that is supposed to work on Verizon is [email protected].
Ensure that the server settings you are using are correct:
1. Incoming mail server (POP3) - incoming.verizon.net.
2. Outgoing mail server (SMTP) - outgoing.verizon.net.
Ensure that you have not set the Log on using Secure Password Authentication (SPA)
Ensure that ports are POP3 PORT: 110. SMTP PORT: 25
Turn off any active firewall or security software. Also ensure that your router is not blocking port 110 (for POP server) or port 25 (for SMTP).
If all that does not work, then there may be an issue that depends on Verizon server. Also try calling Verizon online to find out if there is any additional issue that can affect your account.
Regards.
3answers
Outlook 2007 Address Book Corrupt
To resolve this issue, remove and reinstall the Outlook Address Book. To do this:
  1. Start Outlook.
  2. On the Tools menu, click E-mail Accounts.
  3. Click View or change existing directories oraddress books, and then click Next.
  4. Click Outlook Address Book, and then click Remove.
  5. Click Yes when you receive the prompt to confirm the removal.
  6. Click Add.
  7. Click Additional Address Books, and then click Next.
  8. Click Outlook Address Book, and then click Next.
  9. Click OK when you receive the message to restart Outlook.
  10. Click Finish.
  11. Click Exit on the File menu to quit Outlook.
  12. Restart Outlook.
  13. In the Folder list, right-click the folder that you want touse with the Address Book (for example, right-click Contacts), and then click Properties.
  14. Click the Outlook Address Book tab.
  15. Click to select the Show this folder as an e-mailAddress Book check box (if it is not already selected), and then click OK
12/19/2016 9:11:19 AM • Microsoft Office... • Answered on Dec 19, 2016
2answers
We are trying to send emails using microsoft
Outlook Complaint here Outlook Hotmail Up or Down
11/1/2016 11:12:26 AM • Microsoft Office... • Answered on Nov 01, 2016
2answers
How do i share my calender
In Calendar, in the Navigation Pane (Navigation Pane: The column on the left side of the Outlook window that includes panes such as Shortcuts or Mail and the shortcuts or folders within each pane. Click a folder to show the items in the folder.), click Share My Calendar.
Do one of the following:
  1. In the Name box, click Default.
  2. Under Permissions, in the Permission Level list, click the permission level that you want.For details about permission levels, see Outlook folder permissions.
    You can create custom permissions by selecting the check boxes and options under Permissions.
4/20/2016 6:57:38 PM • Microsoft Office... • Answered on Apr 20, 2016
2answers
How to recover Exchange 2007/Outlook 2010 Address Book list
Yes the contacts were all in All Contacts through the emc but not in outlook. I think I figured out how to fix this by using powershell to hide all the contacts from the exchange address list and then turn them all back on. Syntax I used is below: get-mailcontact -resultsize unlimited ' set-mailcontact -hiddenfromaddresslistsenabled $true and then when done get-mailcontact -resultsize unlimited ' set-mailcontact -hiddenfromaddresslistsenabled $false Solution was very simple, getting to it was painful! Also: Recovery ToolBox for Address Book is a great way to retrieve contacts from corrupted Windows Address Books (files with *.wab extension). These files are used by Microsoft Outlook and Outlook Express email clients. The loss of such documents means, that all business and personal contacts (email addresses, phone numbers, mailing addresses and other information) will be lost, too. This program gives you a chance for the successful recovery of all contact information, stored in wab files, without the assistance of 3rd party services. For more information: https://outlookexpressaddressrecovery.recoverytoolbox.com/ If doesn't help, look here: http://www.filerepairforum.com/forum/other/other-aa/address-book/954-address-book
4/12/2016 9:41:58 AM • Microsoft Office... • Answered on Apr 12, 2016
I just keep getting a message saying there was an error and can't access my hotmail account. what now?
I just checked mine, I have no problem getting in, so they are not upgrading try using another browser if that does not work it is most likely spyware or malware that is causing your problem, run spybot search and destroy, you can find that here Thank you for downloading Spybot Search Destroy from CNET Download com
3/24/2015 7:23:09 PM • Microsoft Office... • Answered on Mar 24, 2015
2answers
Outlook emails are blank
What version of Outlook? Unless I hear otherwise, I'll assume you're running
Outlook 2007.
I'm not sure I completely understand what you mean. On a "common" setup,
going from left to right; you have your Navigation Pane, Message List, and
then the Reading Pane (Preview Pane).
What I'm getting out of this is: Your messages are all showing-up in the
Message List. However, you can't see the actual body of the message in the
Reading Pane. When you open the message, you still can't see the actual body
of the message.
Do I have this right? Or, are you saying there is some Window popping-up
behind the main Outlook Window and the message Windows when you open a
message? If so, what is that Window titled? Is there an error or something
on that Window?
If the issue is the message body is no longer displaying in the Reading Pane
or when you open a message, I need to ask if you're using some type of
anti-virus scanner that is hooking into e-mail. I believe AVG is the popular
culprit. There is a "Certify Mail" option in AVG we want to disable.
If there is no AV scanner in-play here (AVG or otherwise), open one of these
Now, select the Options tab above the Ribbon. What format is highlighted
here? Plain Text, HTML, or Rich Text? If it's either of the latter two
formats, try selecting Plain Text (Select Continue on the warning box). Can
you see the body of the message now?
Please post your feedback and Vote if the problem resolved as per your satisfaction.
9/25/2014 5:28:59 PM • Microsoft Office... • Answered on Sep 25, 2014
I have a folder in my picture file that I'm trying to delete, it says I need permission for administrator to remove it .
Hello , is your account an administrator account? you might need to log in as administrator and then you can delete the folder
4/7/2014 8:20:19 AM • Microsoft Office... • Answered on Apr 07, 2014
Inbox emails gone
You may have to create a new mail profile in Outlook. or try;support.microsoft.com/kb/272227 This link shows you how to use the inbox recovery
11/27/2013 5:08:25 AM • Microsoft Office... • Answered on Nov 27, 2013
2answers
I need a product key for my Microsoft Office 2007.
To download the product key you will need a torrent application such as vuze and to download this go to http://download.cnet.com/1770-20_4-0.html?query=vuze&tag=srch&searchtype=downloads&filterName=platform%3DWindows%2CWebware&filter=platform%3DWindows%2CWebware After you download the torrent application go to this url: http://isohunt.com/torrents/?ihq=MS+office+2007+keygen Choose one of the keygens to download preferably one with more S's or seeds. Download the file(oh and beware check if there are any negative comments on the download before downloading) and then double click on the downloaded file. Vuze should automatically be opened and should start downloading soon enough. Double click on the opened file and you should have a keygen to generate you a product key for MS office
12/2/2011 6:05:20 AM • Microsoft Office... • Answered on Dec 02, 2011
Pdf preview handler error when trying to open,
Microsoft Office does not support PDF files by itself. This has to be an issue with the program that you are using to view PDF files.
My suggestion would be to do download FoxIt PDF Reader from http://www.foxitsoftware.com/products/reader/ and try that, it's what I use, and it's FAR more secure than Adobe's PDF Reader.
They also have a pro version, which is much less expensive than Adobe PDF.
Hope this helps!
6/16/2011 4:11:46 PM • Microsoft Office... • Answered on Jun 16, 2011
2answers
How can i get office 2007 free?
You cannot legally get a copy of Office 2007 for free. Any license keys you find on the Internet are going to be pirated keys and illegal to use.
1/19/2011 6:05:26 PM • Microsoft Office... • Answered on Jan 19, 2011
I want my email message
Open the windows controle panel.
Click on Sounds. Here it is possible to activate sounds and also for incoming E-mails
1/19/2011 6:00:34 PM • Microsoft Office... • Answered on Jan 19, 2011
Want open from desk top
Copy your outlook Icons to desktop and you are able to open these programs direct vfrom your desktop.
Right click on the Icon - copy etc - place the Icon on your desktop via "insert"
1/19/2011 5:55:42 PM • Microsoft Office... • Answered on Jan 19, 2011
Can you give me a key for outlook2007. I only use
OFFICE-2007 PRO Serial No- KGFVY-7733B-8WCK9-KTG64-BC7D8
12/5/2010 4:35:58 PM • Microsoft Office... • Answered on Dec 05, 2010
Microsoft Office Outlook 2007 for PC Logo
104 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
trying send emails using microsoft
  • Computers & Internet
