Just to verify the model number of your monitor, is it X2Gen MG17J 17" Computer Monitor? If yes, then here's the part number: PDN-48-48A.
This part number is compatible with X2Gen MG17J 17". Check the link below to order it:
http://www.deal-stop.com/ACGN082_GN-25MM-12V-4A-POWER-ADAPTER-PDN-48-48A.lmsp
Thank you and good luck!
No, it's way too low power. Most probably you need 12V and something like 4-5A (4000-5000mA). The higher the current rating (Amps) the better, some reserve is always good to have; the unit will draw as much current as it needs, the rating means the maximum current that the power supply can deliver.
Good luck, and please come back with a rating/testimonial if helped :)
