20 Most Recent X2Gen MG19VT 19" LCD Monitor Questions & Answers
Help How do I make my screen fit the monitor?
heres a link that i found that can help you out. http://www.onlinecomputertips.com/windows/wq66.html
3/2/2016 11:35:34 PM • X2Gen MG19VT 19"... • Answered on Mar 02, 2016
No sund throught monitor speakers
could be driver for audio is miss and also could be that sound card is bad...
8/16/2012 4:34:47 AM • X2Gen MG19VT 19"... • Answered on Aug 16, 2012
My monitor keeps burning up the power adapter,why?
how many power adapter leads have been burnt its getting to hot quite possible it has a short but if its has burnt more than oneclean your computer of dustcheck all connections from motherboard to hard drive make sure they have dust free secure connections
11/28/2011 8:34:54 PM • X2Gen MG19VT 19"... • Answered on Nov 28, 2011
My x2gen monitor is yellow and not legible. any
see the VGA plug is it pluged in good is the same with BIOS first you boot the PC
6/2/2011 8:52:54 PM • X2Gen MG19VT 19"... • Answered on Jun 02, 2011
My monitor speakers are muted and I can not reset.
it's on the menu just press it then it will pop out and just navigate to the sound menu then uncheck the mute
5/24/2011 4:23:19 PM • X2Gen MG19VT 19"... • Answered on May 24, 2011
My power cord does not work anymore, i need to
http://cgi.ebay.co.uk/12V-X2Gen-MG19VT-replacement-power-supply-/400197777357?pt=LH_DefaultDomain_3&hash=item5d2da577cd
3/3/2011 2:42:26 AM • X2Gen MG19VT 19"... • Answered on Mar 03, 2011
Budmrtn, Thanks for your help so far on my "out of
Go back to boot up menu but dont restart the computer yet. go to start>right click computer>properties>device manager>under display adapter select your video card right click it and uninstall it.
after uninstalling restart the system; reinstall the video driver for your graphics card.thanks
1/14/2011 9:10:19 PM • X2Gen MG19VT 19"... • Answered on Jan 14, 2011
MW19r powers up but sceen remains black
If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
10/8/2010 5:45:05 PM • X2Gen MG19VT 19"... • Answered on Oct 08, 2010
Looking for the adapter 12v 3.3 a where can I
http://www.12vadapters.com/
You can use higher current rating (more capacity) but not higher voltage.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
9/7/2010 11:06:55 PM • X2Gen MG19VT 19"... • Answered on Sep 07, 2010
4answers
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
8/16/2010 7:34:26 PM • X2Gen MG19VT 19"... • Answered on Aug 16, 2010
Lost manual
I suggest you follow the link below to search for the manual of your device, the link contain virtually all the manuals of all device.
manualsonline.com
Type the above link on your web browser to search and download the manual of your device.
Take care.
6/29/2010 8:56:40 PM • X2Gen MG19VT 19"... • Answered on Jun 29, 2010
How can I use anything above 4-bit
You need to load correct Video card driver for your PC. Make and Model?
6/9/2010 3:06:17 AM • X2Gen MG19VT 19"... • Answered on Jun 09, 2010
Buzz coming from speakers
Buzzing is usually caused by bad audio ground connection. Try insert and reinsert the audio cable first. It can also be the sound card. Try using the MP3 player as the sound source feeding the monitor, if it still bad then it can be problem in the DC filter caps in the power supply, or bad sound IC in the audio board inside the monitor. Please post back what you find.
5/7/2010 5:24:49 PM • X2Gen MG19VT 19"... • Answered on May 07, 2010
Power turns off and on fr abour 5 minutes before finally staying
This is a classic symptom of a failing power supply. After 2-3 years of use many LCD power supplies will start fail because of parts called capacitors that start dying due to the heat buildup in the monitor case. If you can solder then you should be able to do the repair yourself. Check out this page on our web site; http://www.ccl-la.com/blog/index.php/capacitors/ This article explains what capacitor are, how they fail and what you will need to get for the replacement parts. The parts can be ordered from many places on the internet, we stock they too. If you don't want to do the repair yourself we do offer a repair service, that info can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps you, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
5/1/2010 5:25:22 PM • X2Gen MG19VT 19"... • Answered on May 01, 2010
All I get is a note on the screen saying
Try it on another PC first to narrow down the problem before start taking things apart. If it still does not work with other PC, then you need to look inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
4/4/2010 9:54:24 PM • X2Gen MG19VT 19"... • Answered on Apr 04, 2010
X2Gen MG19VT 19" LCD Monitor Logo
Popular Tags
39 questions posted
Top X2Gen Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
ADMIN Eric
ADMIN Eric
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • X2Gen Computers & Internet
Most Popular Question
help make screen fit monitor
  • Computers & Internet
