20 Most Recent
Harman Kardon HK206 Computer Speakers Questions & Answers
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Where can I purchase a harman/kardon transformer
http://www.ebay.com.au/itm/NEW-AC-Adapter-Power-Harman-Kardon-A481511OT-HK195-01T-HK-01T-Transformer-PS-/120792830300?pt=LH_DefaultDomain_0&hash=item1c1fd0515c
Ebay $16.49 + $23.28 postage
postage the great killer you might be able to find one a bit closer to save on postage (local pickup)
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps you
One Speaker no longer works,
Hi !
Most of the time there isn`t any problem with the speaker but with the cable connecting the 2 speakers .Try to listen some music and move the cable a little and maybe you`ll hear the sound coming out from the dead box .
The cable is not that hard to be replaced but you will need a new cable and a soldering tool, ( or someone who has one )
But the majority of the people are just buying a new set a speakers when one brokes because these are one of the cheapest parts that can broke on a computer...same for the mouse or keyboard , a good specialist can still fix it but it doesn`t worth it if you can afford new ones.
Hi, I want to install
connect the green jack of the speaker to the headphone port of your laptop. Connect the speaker to power and turn it on.
If you bought the HK 206 speakers brand new, there should be a driver (CD). But if you don't find a driver, that's no problem.
If there is no sound, please let me know for further assistance.
Regards.
My left speaker does not function. That's
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Left speaker dont work at
connection is good
hope this helps
Speakers Serial Number from bottom of speakers:
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
any of these you will need to update or install drivers Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar
if his does not fix the
problem
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
connection is good
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this helps
What size power adapter does it use?
You need a AC to DC power supply capable of supplying 120VAC in, 12VDC out @ 1 amp (1000 mA). The center of the plug must be + and the outside -. I believe Dell supports these speakers and may have the power supply available. Radio Shack might have a substitute PS as well, you just have to match the plug size. Be careful what you pay for it, a new pair of these speakers can be purchased for around $20.
Here is a 12v 1500mA adapter (the mA rating can be higher that what you need, but not lower) from Radio Shack
http://www.radioshack.com/product/index.… but its more expensive that a new set of speakers.
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
