20 Most Recent X2Gen MW22U Monitor Questions & Answers
0answers
0answers
0answers
The MW22U displays horizontal grey stripes that
Hey there.
I have recently written a tip on this problem. I suggest you give it a read and let me know how it goes.
You can see my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Enjoy my tip.
Slasher_X
8/16/2011 10:15:51 PM • X2Gen MW22U... • Answered on Aug 16, 2011
Wont power on. When I
It can be bad power pack due to bad caps (bulging/leaking top): http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/?action=view&current=badcaps2.jpg
Or there are shorted circuits in the monitor caused it to draw too much current from the power supply, but I doubt that since the power supply will go into shutdown mode to prtect itself.
I would try another power supply first.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
8/11/2011 10:00:02 PM • X2Gen MW22U... • Answered on Aug 11, 2011
Monitor goes blank randomly - have to turn off
It may have dying power supply due to bad caps with domed top, that will be the first thing to look for since it is very common problem with ALL the LCD monitors.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
4/27/2011 3:27:18 AM • X2Gen MW22U... • Answered on Apr 27, 2011
How do I resize the images on the screen. They are
Download _FREE_ software named "The Graphical Image Manipulation Program"
Among many things, it can "crop" and "resize" pictures.
4/8/2011 9:39:23 AM • X2Gen MW22U... • Answered on Apr 08, 2011
The monitor is going into sleep mode and not
Sounds like the problem I'm having. Research uncovered a common problem with failed capacitirs on the power supply board. If you look at the tops of the electrolytic capacitors on the power supply board and any of them is bulging, you've found the problem. Check out http://lcdalternatives.auctivacommerce.com/Repair-Kit-X2gen-MW22U-DCAC0006-LCD-Monitor-Capacitor-P1799919.aspx for replacement capacitor set.
3/26/2011 6:27:32 AM • X2Gen MW22U... • Answered on Mar 26, 2011
Computer will not boot with
There are several problems areas that will need to be checked.
1. Are all power cables connected properly? As well as all video cables. 2. Does the computer actually turn on?
If the answers are yes to those. You may have to open up the case of the computer. Double check that all memory modules are connected fully(Make sure the RAM is seated fully in their proper slots). Make sure all video cards are seated properly and that the CPU is installed correctly.
As this is a general trouble shoot for your question, with more information pertaining to your exact computer.... I can be of further help.
3/2/2011 3:29:16 AM • X2Gen MW22U... • Answered on Mar 02, 2011
What size screw do I use to mount this thing to my
Metric M4 or M5, they are about 50cent each at HD or LOWE'S. The length will be determined by the thickness of the plate that the screws will have to go through to go into the thread on the back of the monitor.
1/27/2011 1:06:43 AM • X2Gen MW22U... • Answered on Jan 27, 2011
I'm getting a "VGA" window a lot in the upper left
The source of the signal is constantly rediscovered because it constantly gets lost - check the cable and how it's fixed in the monitor and the pc. Prepare yourself to spend some money on a new video card.
9/19/2010 7:43:43 PM • X2Gen MW22U... • Answered on Sep 19, 2010
Monitor seems to be in
It sounds like the actual screen has a problem. Go ahead and turn off the monitor, then unplug the data / vga cable (the other cable besides the power cable) and turn it back on. Do you get a no signal error or anything on screen, or does the light stay amber? If it is still amber this means it is having internal failure, more or less the monitor has died. How old is this monitor? Did you purchase it with a major credit card? If so many credit cards cover electronics such as this for 5 years regardless of the manufacturer's warranty. I know for example that American Express definitely does this, and they would give you a full refund on the monitor if you purchased it with their card. I know it sounds too good to be true but I assure you it is, I've done it a handful of times without issue.
Please let me know what you find, but I would bet the monitor has failed. Luckily you can buy replacements very inexpensively, for example this would be a great replacement:
http://www.amazon.com/gp/product/B002BZA54S?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B002BZA54S
If you don't need one as large as the one you have now, you could save over $40 by going to a 20 inch such as this one, it is an excellent monitor as well:
http://www.amazon.com/gp/product/B0030BLZEG?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B0030BLZEG
Hope this helps, let me know if you have more questions,
Tim
9/14/2010 3:59:51 AM • X2Gen MW22U... • Answered on Sep 14, 2010
When I Turn On The Power.I Lights Momentarily And
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
6/13/2010 7:41:13 AM • X2Gen MW22U... • Answered on Jun 13, 2010
My x2gen mw19r monitor keeps turning off i will
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
6/10/2010 9:59:54 PM • X2Gen MW22U... • Answered on Jun 10, 2010
22 lcd monitor. When turned on, logo shows up for
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
5/25/2010 12:35:11 AM • X2Gen MW22U... • Answered on May 25, 2010
When powered up,my 2Xgen monitor works for 2.5--3.5 seconds.
Check the power supply for bad caps.
5/23/2010 11:00:22 PM • X2Gen MW22U... • Answered on May 23, 2010
Power light comes on but screen is black and no
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
5/15/2010 1:04:34 AM • X2Gen MW22U... • Answered on May 15, 2010
X2Gen MW22U Monitor Logo
60 questions posted
Top X2Gen Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
ADMIN Eric
ADMIN Eric
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • X2Gen Computers & Internet
Most Popular Question
wont power when
  • Computers & Internet
