The kitchenaid fell out of hands while moving and landed on speed lever. it is now bent and jammed at full speed. How can I get the mixer apart and either repair or fix the lever.
Thanks,
Tim
Hi TIMDEIST, I hate it when you drop your mixer... they’re really not designed for gravity testing. Let’s see what you can do to get it fixed and operable again. The good news is that this can be fixed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals& Guides> then enter the visitor type “Consumer” and enter the 6 character model number, in this case K45SSW, and then select the file under Parts List (1) K45SSWH0.pdf (341.41 KB) (definitely check to see it this matches your mixer).
Although not providing step by step instructions, the Parts List manual provides an exploded view of the various component assemblies allowing you to see how the mixer all fits together. It is helpful for the disassembly, troubleshooting, and reassembly of your mixer.
Turn to pages 6 & 7, titled “Motor And Control Parts”, and locate Ill. Nos. 1, 2, 3, & 4. #3 is your Switch Lever and stud. If you can’t straighten it out then you will need to replace it. It might also be a good idea to check and see if anything else might be out of alignment due to the sudden stop when it was dropped.
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping. Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, fix/replace your Switch Lever, and reassemble your mixer.
Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
