Lite On LVW-1107HC1 DVD Recorder Logo
Posted on Jun 25, 2010
Unit worked flawlessly for several years. Now when I put in a blank disc, it spins it for about 5 minutes to "initialize" then ejects it as invalid. Help.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
937
Points
5
When mine acts up I turn it off, unplug the power in the back, and while holding in the power button up front, I plug it back in. When you ley go of the power button the light will first go green then shut off to red and you can turn it back on to test. It doesn't work for all bugs but it has worked for me in the past for a few glitches. I also have tried uplugging for a few days to get bugs and perhaps static out. A good cleaning with a dvd cleaning disk never hurt, and rubbing the unit down with a anti-static dryer sheet can sometimes alleviate static issues after a rest unplugged.
Keep getting "Fail" on blank discs
The LVW-5005 DVD Recorder came with a list of recommended brands for each type of disc, and they are all different in all categories. Some brands are recommended for CDs, some for DVDs, etc. They are not the same in any catagory. Most of the ones I bought were not on the list, because I couldn't find those listed anywhere in my neighborhood here in California. Some worked before, but are not working well now. Some have never worked, and some are failing intermittently.
The INVALID DISC message comes up on both units often, but when it comes up on the LVW-5005 unit the DISC eject feature will not eject. The open close door stays shut and says it is open, but sticks and keeps trying to reread the disc. You actually have to tip the machine down to let gravity help, and then turn it on and off and on and off and it finally opens and drops out the invalid disc.
The LVC-9016G unit says "change disc", or gets stuck on "Preparing". Sometimes it prepares, and then I can actually record, but when I try to load it later..... FAIL! This too is INTERMITTENT. GOD I HATE THAT WORD!!!!
I am not good a taking machines apart, and I have a MAC system 10.5 computer, and the firmware update seems to be geared to the WINDOWS PC. HELP?? Is there anything I can do.
Also IS THERE A LIST OF PREFERRED BRANDS of the media for the LVC-9016G model. It may be the same as the list for the LVW-5005 unit, except the that unit is supposed to record on CDs as well. NOT SURE> None are working consistantly.
The other idea that I had is that the newer DVD-R and DVD-RW or the DVD+R and DVD+RW discs have a heavier technology and these older burners (2 years makes it older, I guess....) and seem to no longer like them.
The 6 hour SLP I always set them to record on in the past, may no longer be valid. The 4x, 8X 16X etc. may not work either. Since I don't understand what that means, and we only have access to what is available to buy, I am at a loss there too. I am logical, but not technically educated in this technology. I come at this with psychology, not technology... :-)
I have the LVC-9016G for 2 years, and the other bought at COSTCO only a year ago. Is $300 worth of equipment already obsolete?
I have not hacked or touched anything. I may need to buy another lense cleaning disc. I have a memorex one, but when I put that in it said INVALID DISC, and will not work either. Won't read or spin.
I am frustrated...http://club.cdfreaks.com/images/smilies/6/eek.gif.
Candy user_offline.gif this can be due to invalid media........all types will not burn in this unit........good success....meder's tv service
3answers
Initializing DVD
Try to clean lens eye wth a specific cleaner, and try again
tip
LGRC797T Getting Stuck on INITIALIZE DISC?
Problem - You put the DVD recordable media in and it takes about 30 seconds before it identifies the disc and says Initialize Disc?
You click OK and it takes the full 2 minutes only to stick after 2 minutes and do very little but spin. Disc will not eject unless power is removed first.
Disc will read DVD's ok.
Solution - Clean the lens with a cotton bud and Isopropyl Alcohol very gently. Shine a flashlight onto the lens to see if the reflection is clean. If not the soft wood of a match stick with a small piece of clean silk can be used to rub the lens with as little pressure as possible.
The DVDR should read and the initialize, although it says will take 2 minutes, should jump to the end quickly and the DVDR+ sign appears in the corner.
(My problem first occurred after some painters were sanding in the house and the machine got full of dust, but the clean did not last long and it turned out there was a smudge on the lens which you could not see without the flashlight. Once it was removed the recorder was back to working order.
on Dec 02, 2008 • LG RC797T
5helpful
3answers
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Disc drive ejects blank discs...plays dvds
Hi Again,
Sorry I didn't get back to you sooner. Work!
You need to let me know what type of PowerBook G4 it is as the instructions for each are different. However, what I will do is give you the links to the appropriate sites and some instructions for them:
  1. First you need to reset the Power Management Unit (PMU). To do this refer to THIS page. A little way down is a heading 'PowerBook and iBook models covered in this document'. Select the model listed in blue below this which will take you lower down the page to the instructions for your model.
  2. After restarting try your drive again. If it doesn't work, try a dvd drive cleaning disc.
  3. If it still doesn't work your drive is Kaput! If you're near Kent in the UK then I can help you out. If not find a local Apple Specialist who can replace the drive for you.
All the best
Sean
Bose 5 disc cd multi changer wont load any discs from the magazin
That is usually because of dirty or defetive lens, as teh player cannot read the initial track of the CDs.
Try first using a len cleaner , like the ones here.
If this does not work it will be necessary to take apart the unit and accees the lens to clean it, or replace the lens pickup. The repair must be done by a technician.
In this case call the number listed on the owner manual to get assistance
DVD player isn't loading and playing properly
Since it will play eventualy, I'd suspect a dirty lens. Open up the unit and carefully clean the lens using a cotton swab and alcohol. Also, try a music CD. If the CD works flawlessly but DVDs still fail occasssionally, the optics are starting to fail and will need to be replaced.
Dan
7 cd disc changer will not open or work properly
I took off the top then took off the cover of the CDs and took out the CDs then I took out the cd holders and placed them back in and put the top back on and it works now
2helpful
3answers
Presidian dvd recorder pdr 3222
Have had the same problem with my Presidian3222 for the last year, if I recorded something it would come back as invalid disc or blank disc or would not close disc out right, got so damn mad almost took a hammer to it last night, unplugged it like clicky said, did no good, thought cable co may have been sending single to screw up recording, but today took camcorder and tried to record something, same thing which seemed to let the cable co off the hook.
the following seemed to have fixed the problem, first open the player then unplug it, close the drawer 1/2 way, then I took compressed air and blew inside the player to clean the laser after that I have been able to record 3 movies and close the disc properly and finalize the disc properly, I even had 50 new disc made by sony that recorded kept saying were invalid, reads them fine now, I hope this helps everyone, because I was on the edge of putting this thing in the trash last night.
R.J.
2 different "Recording" problems with my unit.........
i think you need to use manual button for increment track number
Top Lite On Televison & Video Experts
Ngoro
ADMIN Eric
ADMIN Eric
August Brown
August Brown
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
