Casio watch displays
open after replacing battery
Check YouTube video for battery replacement process
http://www.youtube.com/watch?v=ogCz2vjUKVg
The open code is saying that your case isn't closed properly. Without seeing it, it's hard to tell if you opened/closed the case correctly. If you believe it is closed properly, look in your user manual and see if there is a master reset button and try that. Did you change the battery yourself or did you have a jeweler do it?
Short out 2 holes with staple cut to size-below copper piece on back you took off
SOURCE: I just repaced my casio watch batteries but i'm
This may sound dumb but make sure the battery is in the correct side up. There should be a + or - symbol on top of the metal piece that snaps over the battery. If that's correct get a pair of tweezers and spread them open, and touch one side to the top of the battery and the other side down inside a little hole with ac marked beside it. That will reset the watch, and your display should come on.
SOURCE: I have a Casio Pathfinder PAG-70 that reads
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
SOURCE: Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
