20 Most Recent
Casio G3011 Duplex LCD Watch Questions & Answers
Is there a reset button? i put a new battery in
No! there is no reset it is possible the battery is not correctly seated, check to make sure the positive and negative match what the watch indicates, because if the battery is reversed it will not work. If you still have issues take it to a watch dealer.
Handleiding
mcdevito75 here, I think you mean handleing, or takeing care of your Casio watch. First look on the back cover to see if it says shock proof or water proof, if it does you have a liitle lee way in handleing your watch, what I men is, you can wear your Casio even if you do heavy work and even in a moderate rain. However most Casio watches should not be worn if your out in a driveing rain or if you do extra heavy work, such as use a sledge hammer, or heavy tools, keep your casio dry, and once every other daye wipe it clean with a soft dry cloth, also do not rest your Casio on it"s crystal (Glass) when you take it off.
Poor cassio watch display
You don't say how old the watch is and whether it has always had a display problem. I have seen several watches with weak displays, but generally they are older watches and I suspect the problem involves a corroded contact somewhere in the "movement". You might want to visit the Casio website and download a copy of the manual for your watch. It may say something about the display. If you watchis fairly new it may still be under warranty and again, contact Casio to see what you need to do.
NEED AN INSTRUCTION BOOKLET FOR A CASIO WATCH MODEL MDV701
You will have some trouble downloading a book. There are so many models that are similar but different. Simply contact Casio directly, - they have dealers & offices literally all over the world- They will have the book you need for less than $5.00.
There is a serial number on the back of the watch, but the one they will need is inside a box on the back of the watch. Good luck.
Casio prt-10 and i broke the display. where i can buy lcd?
http://www.casio.com/support/buyparts/
You're probably going to have to replace the complete guts. Lots of these digital watches have the little buttons on the sides of the case. Those buttons press small springs which makes contact with the button on the "movement". Be careful that the little springs aren't lost when you remove the movement. It's not hard to do, you just need the right parts. A small phillips screwdrive and a sharp probe makes things easier.
In some cases, you will need to force the stainless steel back past the rubber wrist band. These watches are nearly indestructible, so you can apply some force. Just don't apply it to the guts of the watch.
I just repaced my casio watch batteries but i'm
This may sound dumb but make sure the battery is in the correct side up. There should be a + or - symbol on top of the metal piece that snaps over the battery. If that's correct get a pair of tweezers and spread them open, and touch one side to the top of the battery and the other side down inside a little hole with ac marked beside it. That will reset the watch, and your display should come on.
Casio G-Shock G3011
go here [url]http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2454&submit.x=68&submit.y=13[/url]
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
