20 Most Recent Casio Wave Ceptor WV57HA-1AV Wrist Watch Questions & Answers
I tried putting your module number in (3054) and was able to download the instructions.
Try the following link http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3054.pdf . This was successful in finding the manual you require.
Good luck and a happy new year.
Casio Wave... | Answered on Jan 01, 2019
mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
Casio Wave... | Answered on Sep 12, 2018
i think you have a dud, i would conatct casio directly.
this model is radio controlled so will always set it self to the correct local time , i can only think that the watch is switching off an on causing it to reset the date then when it picks up the signal it resets the time.
Casio Wave... | Answered on Sep 19, 2017
My Casio wave ceptor keep resetting itself like this when the bottom right (D button) is pressed. I need to make sure I reset the city code or before trying to receive as it defaults to Tokyo. Press & hold the top left (A button) and date changes to city code. Scrole through codes using right bottons.
Hope this helps.
Nick
Casio Wave... | Answered on Sep 16, 2017
Tip
Performing Watch Battery Replacement
There are different types of watches worn, from the simple, casual designs to the large, Swiss-made pieces of art for the elite. Regardless of the type, they all need routine care and maintenance to keep them running and looking good. One of the best long-term investments you can make in a watch is in battery replacement.
When it comes to watch battery replacement, the first step is to test the battery and ensure that it is the source of the problem. There are numerous watch and battery testers available that will allow you to test watch movement while it is closed.
Once you have determined that the battery is the problem, open the case. As you are proceeding with this process, confirm what kind of battery you have and the correct size replacement you will need. Take a note of the current battery number before you remove it. This will be helpful in case the batter slips out of the case and gets lost. For some batteries, you may need to reset the movement before they can function again.
When you have finished changing the battery, replace the back on the watch before putting it on again.
Certified Watch Repair Battery Replacement MyJewelryRepair com
on Jul 07, 2017 | Casio Wave Ceptor WV57HA-1AV Wrist...
I had the same problem this week and after downloading and reading the operation guide, I found the "adjusting the home positions" procedure in page 2, I followed the instructions and now my Casio 4303 is up and running, I got the operation guide from: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf (thanks to jeffw284 for the information).
I hope this helps to solve your problem.
Best regards.
Casio Wave... | Answered on Dec 14, 2016
You can align the analogue time with the digital time by pressing the mode button until you reach the hand setting position (HS) and then press one of the right hand buttons to change the hand position.
(Check out this with the instructions- it is all there!)
Follow instructions. Just poke pin in at right angle.
Casio Wave... | Answered on Aug 01, 2016
mcdevito75 here, 1 of the buttons should say MODE, press this button and see the display blinking, NOW! press the set button for each function, after each function is set press MODE to move onto the next function, when all functions are set, press MODE again to see steady display.
Casio Wave... | Answered on Nov 15, 2015
I take mine to a watch dealer to get the right, freshest battery from someone with the right tools to install it. Peace of mind.
Casio Wave... | Answered on Mar 03, 2015
This same problem (watch resetting to 1/1/205) has happened to me 2x now, about 2 months or so apart.
I have had this watch for ~10+ years now, and works perfectly.
I have replaced the battery 2x.
Again, the watch works great.
I just realized that in the .pdf manual, there is no indication for a "low-battery" condition.
I am guessing that the "low-battery" is what is causing the watch to reset the date/time to 1/1/2005.
Any others having this same problem if this watch resetting to 1/1/2005 after the watch has run just great (auto time syncing, etc.)?
This watch Keeps great time!
Buster Brown
Casio Wave... | Answered on Dec 30, 2014
The Casio wave scepter watches often got put on sale because the booklet was thick and the sales staff inside their steel shell stores could never prove how it worked. I bought 3 from Sears at a low price.
Ok, I am in northern ontario, and I set the watch around a non metal tube or box - like a paper towel roll or small pop bottle and set it on a south or west facing window ledge. Works best on a top floor. Position the watch so the 12 is pointing to Fort collins.
My casio at this distance doesn't pick up the radio signal until sometime between midnight and 6 am. It has a setting that reveals if it did sync and reset the time, and will show at what time it sync'ed.
casio watch manuals are available online. As long as you have set what time zone you are in, it will set the time.
Casio Wave... | Answered on Dec 11, 2014
Actually this is a simple procedure for a watchmaker or a person that changes alot of batteries, you don't need to send it anywhere, for the price of postage you can get someone to reset your watch, It is not actually a button but a spot on the circuit board that is shorted with tweezers to the positive side of the battery. This procedure is usually done when you install a new battery.
Casio Wave... | Answered on Aug 29, 2014
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
367 questions posted
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Ceptor Casio
  • Ceptor Casio
Most Popular Question
oh one additional thing about casio wave
  • Watches
