20 Most Recent Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Questions & Answers
Casio protrek prg 505T users manual english
hi i have prg-505t . i want reset factory .....??
5/25/2022 2:16:16 AM • Casio Triple... • Answered on May 25, 2022
Casio PAW-1200T Tough Solar Pathfinder
so here is the fix if you get op en display on your casio pathfinder or whatever model. mine happens to be a paw 1200t1. you gotta break it open 2 pins each side band comes off.2. pry off the side pieces. this exposes 4 screws.3. the base then comes off be careful of the gasket. 4. once inside. notice a round circular object on the base and a small oval shiny gold copper piece. 5. For whatever reason the shiny copper piece has shifted and does not make contact with the tiny little springs there are 2 if you shift the base to make contact with the gold piece the op en goes away and watch is back to normal. 6. the fix is move this little piece back to where it belongs. i got lucky and the glue still held when i firmly moved it to its original location. super glue came to mind if it wont stay where it belongs.7. gasket orientation and cleaning out the gasket channel is a given i used welding tip cleaners to do the intricate work. under the bands are very grungy. mine is about 5-6 years old. reassemble the way it came out. if your battery is good and you get this op en look to your display for whatever reason this worked for me and if casio uses this as a warranty or warning of water coming in your watch it was a STUPID DUMB IDEA. those springs should be solid state and the watch is useless until it is fixed no light, no baro, no alt, no comp. notta and no buttons work. there is no reason whatsoever that this shiny copper thing shifts but it happened to me and my watch is working and my battery has had H or full power since day one.
2/24/2020 9:56:41 PM • Casio Triple... • Answered on Feb 24, 2020
Casio Pathfinder 2273 Reassembly Help
Hi there these small springs sit under battery connector tabs (Below)copper colors tabs so that theres enoughe spring pressure, for your watch to run. Hope this makes sense and remember its just a watch so dont stress out, lifes short and you never now when that meteors going to come in and vaporize us.
12/4/2016 7:09:15 PM • Casio Triple... • Answered on Dec 04, 2016
0answers
Paw-1200t
may be some dust inserted into the watch which prevents you to press the buttons .another prob might be low battery. put your watch in sun in order to give some power to your solar battery
11/12/2013 10:57:50 AM • Casio Triple... • Answered on Nov 12, 2013
3answers
Casio says open
The open code is saying that your case isn't closed properly. Without seeing it, it's hard to tell if you opened/closed the case correctly. If you believe it is closed properly, look in your user manual and see if there is a master reset button and try that. Did you change the battery yourself or did you have a jeweler do it?
3/12/2013 8:02:53 PM • Casio Triple... • Answered on Mar 12, 2013
2answers
I left my watch in the dark for a along period of
If you left your watch in direct sunlight, there should be just 6-8 hours enough to recharge it. If there was no direct sunlight, it may take up to a week to revoke your watch. This corresponds only to watches powered by light. The energy cell in those watches is called capacitor, not battery. If you are not sure what type of cell your watch has, leave it for a few days more in bright lightened place and then see if it works. If it does not - replace the capacitor (or battery if your watch isn't powered by light). Rate me, plz.
8/12/2012 10:53:13 PM • Casio Triple... • Answered on Aug 12, 2012
My Casio protrek prg 60
probably one of the buttons of your watch is stuck that's why you cannot use the other buttons of your watch. it has to be opened and check for it, mostly of the button that are stucked with this kind of watch is the illuminator or the light located at the lower middle of your watch. i hope i had helped you.
7/25/2011 12:53:55 PM • Casio Triple... • Answered on Jul 25, 2011
0answers
Turn on-off auto l.e.d. light
1-goto this link http://world.casio.com/wat/download/en/manual/
2-follow the instructions and download the user's manual for your watch
1/28/2011 11:03:18 AM • Casio Triple... • Answered on Jan 28, 2011
3answers
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
1/9/2011 1:55:22 PM • Casio Triple... • Answered on Jan 09, 2011
I have an older model casio watch with
you should be able to get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
12/24/2010 12:33:07 PM • Casio Triple... • Answered on Dec 24, 2010
2answers
Compass comes up with RECO, what does this mean?
If you use the backlight of the alarm a number of times during a short period, RECOV appears on the display. After some time, battery power will recover and RECOV will disappear, indicating that the above functions are enable again.
10/25/2010 5:28:30 PM • Casio Triple... • Answered on Oct 25, 2010
Hola tengo un casio prg80T pro trek aparece en la
I know the secret behind CASIO's "OPEN" problem. This is not a joke. You'll be happy to get your watch working again. Because the procedure is too long to fit in here, send me an e-mail at [email protected] and I'll send you the solution. This is no scam.
10/6/2010 6:33:28 PM • Casio Triple... • Answered on Oct 06, 2010
What is the procedure to make the watch switch the
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/6/2010 1:16:19 AM • Casio Triple... • Answered on Sep 06, 2010
Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
59 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
casio paw 1200t tough solar pathfinder
  • Watches
