Frost buildup on food and ice around the door is due to warm air infiltration. This sounds like a door closure problem. Be sure that nothing is interfering with the drawer as it closes. Be sure to open the upper door and look down at the drawer top to see that the gasket is hitting the steel frame of the cabinet. Look all the way around the entire drawer front checking the seal.
Also open the drawer and hold it as it closes, so that if there is any food product binding it you will see it get hung open.
Good luck.
I have the same problem - even with the moisture control turned on, the bar where the freezer drawer closes is cold... the seal and insulation are very poor. We have two different Jenn Air refrigerators in the house, the other one is super - this one is junk but I haven't been able to get anyone to take it back. I doubt that the boasted Energy Guide rating is right - this fridge just not properly designed. Plus, the air temperature in the fridge swings wildly... put a thermometer inside and see. This isn't good for properly storing food.
