Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Whirlpool Cabrio dryer takes forever to dry anything (3 hours for just a couple shirts!). There is a code AF flashing on the display window, but i have checked all the airflow issue places and nothing is clogged. What else could be wrong?
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Jun 08, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10845415
Points
101584
Hi, If you have a gas dryerMy Whirlpool Cabrio dryer takes forever to dry - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_notMy Whirlpool Cabrio dryer takes forever to dry - 2_bing.gif/>If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...Dryer
Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
MY WHIRLPOOL CABRIO DRYER IS BLOWING HOT AIR BUT CLOTHES ARNET DRYING. CLEANES THE VENTS FROM THE OUTSIDE AND THE AF SENSING CODE KEEPS FLASHINGS WHAT DO I DO? PLUS IM GOING CRAZY I HAVE FIVE KIDS......
This is an air flow issue. Take the hose off the back of the dryer and run it and see if the error goes away. If it does not, something is plugging the inside of the dryer airflow.
Aug 08, 2013 • Dryers
Dryer takes forever to dry even after i cleaned the vents out
don't forget the exhaust tube coming from the back of the dryer and leaving the building. those can get pretty restricted with lint. Another place to look is inside the cabinet for lint. Getting these cleaned regularly can prevent a fire.
Dryer not drying-the sceen has af flashing please help..whirlpool cabrio
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
Thanks for using FixYa.
1helpful
2answers
Whirlpool dryer Cabrio 6 months old. message on screen is "AF" what does that mean?
Code AF means the air flow is blocked.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 07, 2011 • Dryers
On the screen of my dryer where it tells me how long I have till the cloths are dry keeps flashing AF and it takes me all day to dry one load of cloths.
The AF stands for Low airflow condition. We had it too. Check the lint trap first as it is the easiest. Then check the dryer hose ductwork make sure its not crushed or blocked. You may need to clean the line from the outside too.
1helpful
2answers
I have a whirlpool electric dryer (cabrio) every now and then it displays a code of AF what does that mean
I checked all the obvious things posted throughout the internet about this code on my 5 month old WED7800XL and none of them were the problem. What I found on my dryer was the belt that drives the fan had come off. After further inspection I also noticed that the pulley on the top of the fan was missing. After removing the front panel from the dryer I found the pulley, reinstalled it and the belt, the removed panels and it was fixed.
Also FYI, underneath the electronic panel there is a service manual for the dryer.
1helpful
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 • Dryers
Whirlpool cabrio dryer
af on your cabrio dryer means clean your air filter
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
