Onkyo TX-SR605 Receiver Logo
Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My wii is connected through component cables and runs to tv HDMI
My wii is connected through component cables and goes to my tv through the hdmi cable. What happens now is the screen will flash black and say check signal cable. The cable hooked up to the tv work perfectly. The unit used to not do this. Only thing I can guess is the unit gets hot and somehow affects the component swicth via HDMI since I can watch bluray and netflix all day with zero problems. Might just have to set it up through the tv and just have the sound through the receiver...
Inno Laur
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on May 24, 2010
Inno Laur
Expert
Level 2:
Scholar:
Answers
93
Questions
0
Helped
26069
Points
198
In the receiver's main menu or setup on the remote you will find "input/output assign", make sure the "HDMI Monitor" is set to "yes".
This will make sure whatever video source is connected will be upconverted and outputted to the HDMI going to your TV. If it is set to "no" it will not show your Wii.
No component video with my Wii (component audio and HDMI video/audio both fine). It used to work fine, but now it won't show any picture regardless of which component IN I use. I checked all assigned...
Hello, I am sorry about your issue. Did you make any changes to the output resolution on the Wii. The output must be at 480i for the receiver to up-convert to HDMI. If there is a problem with the receiver I suggest a work around by connecting the component [red,blue,green] video outputs to the TV and the audio connections [red, white] to the receiver. Thank you, Onkyo USA
1helpful
I am streaming netflix from my Nintendo Wii to TV. Is there an after market HDMI cable that I can run from Wii to Denon Stereo to get sound through receiver?
Hello, although there are not official wii to HDMI output cables, there are in fact some cables that are provided by third party handlers that will work.
For instance THIS product is a simple little converter which you put into your wii output and connect a regular HDMI cable.
KEEP IN MIND: This isn't a HDMI cable, you need to have a HDMI cable or buy one to use it with this product.
Can i use a normal over the counter HDMI cord or is there a "special" Wii HDMI?
Hi, the Wii does not strictly have an HDMI connection but the closest thing to it is a Component cable. This has 5 connections and is as close to HD as you can get without a full HD connection. Make sure your TV has component connections on it as well if you do purchase one. They can be bought for around £5 off of places like ebay.
Hope this helps
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
9helpful
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
1helpful
2answers
I have a Samsung led tv nd need a 'component
Hello :
First check this link please : Wii+Television connection
a cable can be found on Ebay or Amazon
I hope that will help .
rate please !
4helpful
2answers
Can the wii be connected with hdmi cable
As was said, there is no HDMI cable for the Wii. An HDMI cable would be a waste on the Wii, considering the Wii can't ouput 5.1 sound, and can't output 1080P (those are the main benefits with an HDMI cable).
The highest qaulity cable for the Wii is a component cable, which will allow you to output the Wii in 480p (progressive scan) vs 480i (integrated scan). All HDTV's have component inputs, so this is a non issue. Component cables actually can output 720p/1080i, but the Wii can only output 480p max.
Here is a link to the cable I am taking about. You should be able to get it from somewhere for the $20 range.
1helpful
My wii connection is black and white
You are connecting it into the wrong input. The Wii comes with a RCA cables that should go into the Video (composite) input that has yellow, red, and white. The component input will not work with the RCA cable input. Plug your Wii into Video1 and you should get the right colors. There should be another HDMI on the side of your TV, there are inputs located both on the back and side of the TV for your convience.
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
