Element Electronics FLX3711B 37 in. LCD TV Logo
harmony brackin Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Element FLX-3710 37" LCD tv will not turn on
The blue light comes on and goes right back off. I can hyear a clicking, like it's trying to kick on then it goes off by itself. I even put in a new fuse. It still same results. On Off On Offr On Off
  • Anonymous Nov 22, 2011
    I have a similar problem with the same tv....FLX3710....i plugged mine into my computer via VGA and it slowly died over the course of a day. The first time i turned it off, with the VGA plug still attached, it would not turn on again until I had removed the vga and power cord, let it reset, then reattached power. Finally, now, it is dead, just a red-light. I gather this is a common problem, but I haven't seen the solution posted anywhere. I changed all the caps on the power supply, even though they tested fine - what else can it be? I am not sure where the fuse is on this, I don't see one on the power supply board, but maybe I am missing the obvious? What is the location and role of the regulating transistor? thanks for your help
Anonymous
Level 2:
New Friend:
  • Expert 68 Answers
  • Posted on May 20, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
68
Questions
Helped
30478
Points
126
Power supply problem of course...set is not dead so line fuse would be good as you said...regulating power supplies are very stable but do contain >>>CAPs<<< caps can leak ,swell do to heat ,etc.
check for visible signs of damage to caps. on circuit board...check regulating transistor( on heat sink)
the >>> on off on off routine<<< makes me think check caps!!!!!
  • hookspiter Jul 12, 2010
    once picture comes on it stays on until I turn the set off
    Then its plug and replug again until it finally comes up ELEMENT
    then sound a picture that is green and like a negative then it will come on with a good picture
Connecting computer to Element flx-3211b via HDMI not working
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Element flx 2210 does not power up automatic after pressing the power buttin
You have classic symptoms of a failing power supply board. As others have stated this is caused by the filter capacitors on the power board. This model uses the 200-000-xxxxtltx power supply which is the same one found in the Polaroid TLS-01911c TVs. Here is a link to a repair guide that shows what to look for and replace on this board to get you TV back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
I have on element flx 2210 22inch lcd tv and when i power the tv to on the little blue light lites up for say 5 to 10 seconds then goes out and changes to amber without coming on and when looking down...
As others have stated your problem is most likely caused by bad capacitors on the power supply board. This power supply board is the 200-000-xxxxtltx and is the same board used in the Polaroid TLA-01911 TVs. Here is a repair guide that shows what capacitors to look for and replace on this board to rebuild it. This is much less than buying a new board even if you could find one for sale.
I hope this helps,
BuddyMc
Any ideas on what to do for an element tv that won't turn back on..the red/blue light is not on either. It was working fine and when I shut it off the red/blue light went out also now I can't get it back...
Tries tv unplug,replug it back like about an hour.By letting the tv resetting itself back to the tv factory setting.Now,the tv should be working again.If it still have the same result.Mean the tv power supply board,that the board where the power a/c plug into it.The causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
When I tried to hook my FLX 3210 up to my computer it failed to turn on at all. I used this same LCD T.V. with my old Acer Computer and had no problems at all.
you may be having a power supply failure. i have seen many problems with capacitors on the power board in those models. are there any lights on the front when it doesnt turn on? if it were a power supply problem then you would maybe get a red light or blue light come on then go back off,
2helpful
Element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
2answers
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
22helpful
10answers
Element flx-3210 lcd tv
I have an element lcdtv 32inch. The tv is less than a year old, i was watching the tv and it just shut off. The red light is on, when i go to power it up, the blue light comes on for a second then blinks, and goes back to red. I know its not a brand name tv, but for 600 bucks, it should last for more than 8 months. Anyone have any advice ?
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
