20 Most Recent Element Electronics FLX3711B 37 in. LCD TV Questions & Answers
Bad power board, it could be a regulator circuit in the board and you can troubleshoot it if your good at electronics as those switch mode power supplies can be a little tricky sometimes, it may make more sense to replace the board though, generally they aren't that expensive, under 50 bucks generally
Element... | Answered on Dec 01, 2017
To receive Digital TV, you need a set-top box from your CABLE provider. There is no TV that will receive Digital TV directly
Element... | Answered on May 20, 2017
You only need a PSU board if the back light inverters are combined with it. Otherwise look for the inverter board. To be sure it's defective, when the picture goes off shine a flashlight on the screen to see if you can spot movement from the program on the screen. If you can see movement then the inverter board needs replacing. If you can't see any movement then the T-Con board is bad. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Element... | Answered on Feb 02, 2016
Check all cable connections, if known to be good, then I would think it is a internal board issue. these boards some times crack connection from heat cycling, boards flex hot and cold.
My first go-to place would be any connectors you removed when you did the repairs -- as since this happened after a period of successfull run-time, HEAT may have caused them to expand to the point where a minimally-connected contact is failing. (And I admire your tenacity on taking on a job like that in the first place!)
Element... | Answered on Jan 30, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Element... | Answered on Jan 24, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Element... | Answered on Apr 09, 2015
Tv LCD Screen panel are cost the same as a new tv,bacause the picture screen panel are 90% importmant to the tv.Tries websites like Shopjimmy.com,Ebay.com might have refurbish tv LCD screen panel for sale.
Element... | Answered on Jan 25, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Element... | Answered on Aug 11, 2014
is it the TV or the source? Does it do this on all inputs? try attaching DVD player.
Be sure all your connecting cables are good & installed all the way on both ends. if still have issue, may be your Main PCB
part#
ELEMENT FLX-3711B MAIN BOARD 899-KE0-UF3712XA1H & Signal Board 899-100-GF271XAH
try this web site for element parts: http://www.ebay.ca/sch/sis.html?_nkw=Polaroid%20899%20KE0%20KF371XA%203H%20Main%20Board%20VSC%2037V1&_itemId=161027387391
Element... | Answered on May 08, 2014
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Element... | Answered on Dec 07, 2013
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Element... | Answered on Nov 22, 2013
Element Electronics FLX3711B 37 in. LCD TV Logo
72 questions posted
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Electronics Televison & Video
Most Popular Question
assure power supply unit psu defective
  • Televison & Video
