20 Most Recent Element Electronics FLX-3211B 32 in. LCD HDTV Questions & Answers
you can go to menu options, than find programming options.
Look for an option called "autoprogram" and select it. It will search and set all available channels.
There is universal remotes for this tv that you can find by googling "elements electronics remotes":
Element... | Answered on Dec 05, 2018
What source are you using? Cable Box? Cable tuner? DVD? Computer?
Most of the time your TV's remote will have a button that says "Aspect" or "View Mode" or "Zoom" they can stretch zoom and distort the screen and cause this.
If it is a DVD or Set Top Box you may have to go into the menu or set-up screen and change the aspect ratio to that of your TV.
Let me know if that helps, any more details would be great.
Thanks!
Element... | Answered on Jan 03, 2017
The worst offender is capacitor EC 13 (this is the location). It is located inside a heat sink shield (iron cage). The value is 25 volts at 330mf. Once the cage is removed replace these capacitors as well. EC14 & EC6, 35 volts at 100mf. EC10 &EC12, 35 volts at 470mf. EC8,EC7,EC9,at 16 volts at 1000mf. EC11,EC12 at 25 volts at 220mf. Please also resolder connection CON3. This connection will allow a good ground to the main board (also known as the signal board. Also you will have to replace diode HER304 (this is the location). This diode is mounted on a heat sink. Replace it with a NTE 576. f you cannot do this find an electronic hobbiest or a TV Shop. Take this info with you. Thanks for asking, Matt of Martins TV Repair.
Element... | Answered on Aug 15, 2016
What type of input and what type of cable have you set to ?
(a) Antenna - Coax cable (75 ohm)
(b) STB - HDMI
(c) DVD - HDMI or
(d) DVD - Red+White+Yellow
(e) DVD - Red+White+Optical (if your TV and DVD support it)
Most TV cannot find any channel when scanned without a proper external /internal antenna
Element... | Answered on Aug 11, 2016
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Element... | Answered on Apr 24, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Element... | Answered on Mar 31, 2016
cold solder joint has cracked on control board probably
Element... | Answered on Jan 20, 2016
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Element... | Answered on Jan 07, 2016
It is not 1 bulb but a series of long cold cathode bulbs with mercury vapor inside. If any one fails, they all go out. If the inverter fails, they all go out. Don't open the panel. Lamps can be tested in the panel by someone who knows how. Very high voltages also. Safer to take it to a shop.
Element... | Answered on May 06, 2015
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
Element... | Answered on Feb 04, 2015
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Element... | Answered on Dec 21, 2014
Refer its user manual for details. If you don't have its user manual, check this site to download it in PDF. Element FLX 3211 Manuals Support and Troubleshooting TVs
Electro help
Element... | Answered on Dec 08, 2014
If it is a new tv it should have warranty so call the seller about it
Element... | Answered on Oct 05, 2014
Element Electronics FLX-3211B 32 in. LCD HDTV Logo
199 questions posted
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Electronics Televison & Video
Most Popular Question
looking location inverter board in
  • Televison & Video
