20 Most Recent Element Electronics FLX-2210 22 in. LCD HDTV Questions & Answers
There aren't any buttons to push on the remote. There are 3 main boards in the TV: Power supply, main, and T-Con board. Do this test. With the TV on shine a flashlight on the screen and look for a faint picture. If you don't see one, then the T-Con board is bad. If you do see one then the backlight driver is not turning on the the white light for the screen. This driver can be on the power supply or the main board. It depends on the model. Since your TV is 10 years old you may want to get a new TV.
Element... | Answered on Feb 14, 2018
Element FLX 2210 User Manual Follow the instructions here.
Element... | Answered on Jul 31, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Element... | Answered on Oct 07, 2015
very unlikely any universal remote will work it might turn it on an off an if your lucky ..very lucky it might give you vol control but no menu operations.
have that one fixed or see if ones on ebay.
or get a cable set top box.
Element... | Answered on May 11, 2015
150W inverter should match with the input power to this TV. Check whether TV has any other faults.
Gopakumar Gopalan Google
Element... | Answered on Aug 13, 2014
HI,
Check you Power cable
Check Connected point
Monitor power button on/off
Some time disconnect power and after 5 to 10 minutes reconnect power cable, if not power on then i suggest you contact HP monitor Technician.
Thanks..
Element... | Answered on Feb 06, 2014
Can be bought from most of the electronic spare part selling shops.
Element... | Answered on Sep 04, 2013
Should be a small round button marked 'INPUT' almost dead center of your remote (assuming you are using the original one) between the '-' signs on the volume and channel buttons and just beneath 'MUTE'. Just keep pressing it until AV is displayed. Here is a link to download your manual my friend: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Good luck with that :)
Element... | Answered on Jun 19, 2013
Sorry I don't but try this web site out!
http://www.tadlys.com/Electronics_medical_police/Televisions/_121.shtml
Blessings,
A/V Media Guy
Element... | Answered on Oct 01, 2012
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps you out.
BuddyMc
That is a common indication of a failure in the power supply board filter capacitors. When the filter capacitors go out the voltages coming from the power supply fluctuate and cause all sorts of picture and power up problems. That model is actually made by Funai and is the same as the Polaroid TLA-01911c TV. They use the same power supply board which is the 200-000-xxxxtitx Here is a link to a repair guide for the Polaroid model that will be the same as for your Element TV.
I hope this information helps you out.
BuddyMc
This is a very common symptom of a power supply that is failing. There are parts called filter capacitors and when they start to fail they can't filter correctly so the power supply can't start. When you keep trying to power it up it will finally do so but the time it takes gets longer and longer as the capacitors get worse until one day it will not power up anymore. The TV uses the same power supply board, the 200-000-xxxxtltx as the Polaroid TLA-01911c TVs. Here is a repair guide for the Polaroid model that shows what to look for and replace on the power supply board to get it back up and running again.
I hope this helps,
BuddyMc
Element... | Answered on Jul 16, 2012
As others have stated your problem is most likely caused by bad capacitors on the power supply board. This power supply board is the 200-000-xxxxtltx and is the same board used in the Polaroid TLA-01911 TVs. Here is a repair guide that shows what capacitors to look for and replace on this board to rebuild it. This is much less than buying a new board even if you could find one for sale.
I hope this helps,
BuddyMc
You have classic symptoms of a failing power supply board. As others have stated this is caused by the filter capacitors on the power board. This model uses the 200-000-xxxxtltx power supply which is the same one found in the Polaroid TLS-01911c TVs. Here is a link to a repair guide that shows what to look for and replace on this board to get you TV back up and running again.
I hope this helps,
BuddyMc
Element Electronics FLX-2210 22 in. LCD HDTV Logo
70 questions posted
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Electronics Televison & Video
Most Popular Question
get parts as power cord adapter
  • Televison & Video
