Sportster radio turns on shows my football team logo and then nothing. checked my outdoor antena connection and good. attached a known good antena and still no channel and no broadcast.
Hi Glenn,
Understandably frustrating, but it sounds like an easy fix.
First, go through the settings on your radio to be certain that nothing was set incorrectly.
Second, make sure your antenna wire is not malfunctioned or tampered with. Broken pins can render an antenna useless. These satellite radio antennae are fairly cheap to purchase on their own, so you could try purchasing a new one and see if it works.
If that's fine, open the receiver. Generally these radio's use small torx or philips screws. Once opened, check the area where the antenna is plugged in - is the lead/wire broken? Is the solder coming off? All of this can be fixed easily if spotted. You can even solder the antenna permanently on if you like.
It sounds like you have entered a AUX mode this is when the device tried to find audio input (for example an ipod) look for a button called Function/input or radio
Are you connected to cable TV or an outdoor antenna? If on cable TV check the signal on another TV or if on an outdoor antenna you will need a digital TV adaptor to pick up local stations due to them not being available in analog anymore. Please take moment to rate my answer. Thanks...
you must first check if the TV card is attach firmly at the motherboard and that the slot is clean (PCI slot etc.) and attach an antena or cable to your TV card.
i hope this video may help you even though its not the same tv card as yours but the installatio process is the same.
(do not delete)
i hope i was able to help you with your problem. TC!
I'm not an expert but I am a daily operator. First check your ground connection, just because the radio turns on doesn't mean the ground is good enough. If this unit is mobile there are several things you can do to reduce the noise. First you need to find out if the noise is coming in thruogh the antena or the power supply; turn on your radio and vehicle, unhook the antena. If the noise goes away or is reduced you know that it is RF noise. this is interference from some outside source, powerlines, TV, just about any thing that uses electricity or electronics can cause noise. relocating the antena may help. Check you antena connections. Check your SWR. This is only a few of the things you can check.
I work for sirius so I know about all of these different issues and the most common one is the connections. It is imperative that the radios be connected to power with the cig lighter adapter. This adapter had circuitry in it that lowers the cars 12 volts to 5 volts which the sirius unit ooerates on. The old units were 12 volt and could hard wired into the vehicles fuse block, but all of the new radios operate on 5 volts. If this is not the issue with either of you then you have defective units. Being that all warranty replacement are with remanufactured units, your chance of getting a problematic unit increases after the initial return of your new unit.
