20 Most Recent Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit Questions & Answers
MY RECEIVER SAYS 'ANTENNA NOT DETECTED'. WHEN I
the outer braid part of the antenna cable has to grounded so what you report suggest that the grounding of the antenna is loose , incomplete but is completed when you move it
11/19/2017 12:00:42 AM • Sirius Sportster... • Answered on Nov 19, 2017
I've had a Spotstar #5 Radio for Home Use since
it could be the signal has been down graded. new laws on signal and strengths have been coming in over the fear of wave format. the best way to gain a weak signal is a booster of some kind to bring in the weak signals, hope this helps.
6/16/2017 8:12:37 PM • Sirius Sportster... • Answered on Jun 16, 2017
0answers
It plays for a shirt period then it turns on and
Power or Signal drop-off can be fix at ebay item# 360454042820http://www.ebay.com/itm/ 360454042820
7/8/2012 6:42:14 PM • Sirius Sportster... • Answered on Jul 08, 2012
My sirius sporter 5 keep turning off and on while driving
7/8/2012 5:36:34 PM • Sirius Sportster... • Answered on Jul 08, 2012
2answers
My sportster 5 satellite radio is not getting signal
Is it "Aquiring Signal" or "Antenna Not Detected"? It could be the antenna, the dock, or the radio itself. For whatever reason, the Sportster 5 seems more fragile in the dock connections. TSS Radio has a repair guy who can fix this issue. You can reach him via email at [email protected]
7/8/2012 5:13:48 PM • Sirius Sportster... • Answered on Jul 08, 2012
I purchased a 2008 g35
Turn the radio on an locate the Radio ID
For XM Radios
Your Radio ID can be displayed by tuning your radio to channel 0. (That's one channel down from the XM Preview.) Make sure to check your ID code carefully. Please note that the following letters are not used: I,O, S, and F.
Call the activation hotline to activate your service
1-866-635-8634
9/20/2011 3:23:17 AM • Sirius Sportster... • Answered on Sep 20, 2011
I have the sportster rewind 2 i did not pay my
If you don't pay your bill, you'll need to buy a new radio, since they'll lock it out of the network. You *might* be able to have it activated online, so try that out before giving up. If that won't work, then just sell it for parts on eBay, if it's a functional (but banned) radio, you'll probably get $20-$40. Make sure you mention it's banned.
9/13/2011 1:04:01 AM • Sirius Sportster... • Answered on Sep 13, 2011
THIS UNIT AFTER 3 YEARS WILL NOT RECGONISE AN
Hi Glenn,
Understandably frustrating, but it sounds like an easy fix.
First, go through the settings on your radio to be certain that nothing was set incorrectly.
Second, make sure your antenna wire is not malfunctioned or tampered with. Broken pins can render an antenna useless. These satellite radio antennae are fairly cheap to purchase on their own, so you could try purchasing a new one and see if it works.
If that's fine, open the receiver. Generally these radio's use small torx or philips screws. Once opened, check the area where the antenna is plugged in - is the lead/wire broken? Is the solder coming off? All of this can be fixed easily if spotted. You can even solder the antenna permanently on if you like.
5/4/2011 10:40:15 PM • Sirius Sportster... • Answered on May 04, 2011
I have 12 volt power coming to the cradle, and
Check the center pin on your unit, and also check if your dock connector has any damage. If it is not damaged, then push on the unit while it is docked. If it turns on after 30 seconds then you have a cold solder joint on your power connector. Just remove the back cover and solder the barrel connector's pins back down. There is one on the left and one on the right, both must be soldered in order to receive power.
4/23/2011 5:37:06 PM • Sirius Sportster... • Answered on Apr 23, 2011
Why can't i get oprah
On Sirius radios, some programs require a subscription to the "Best of XM" and on some XM radios, you need a subscription to the "Best of Sirius" to get their programs. Call XM/Sirius and ask them, but I think that you have to pay extra for the "B.O.XM".
1/18/2011 5:28:31 AM • Sirius Sportster... • Answered on Jan 18, 2011
FM channel set at 88.5, too noisy, need to change
Use the FM extender kit to improve the signal. You can change the channel by holding down the cassette icon to enter the menu, then going to FM options (I think it's under settings)
1/8/2011 7:08:01 PM • Sirius Sportster... • Answered on Jan 08, 2011
2answers
In my settings there is no fm transmitter
As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
12/29/2010 7:07:22 AM • Sirius Sportster... • Answered on Dec 29, 2010
I need a user guide for SP5tk1-24m1
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. Here is the manual / guide, I actually had to find it and put in on my personal server for you:
http://micromatikal.dlinkddns.com:8000/cust/SP5TK1.pdf
10/11/2010 8:12:55 PM • Sirius Sportster... • Answered on Oct 11, 2010
Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit Logo
31 questions posted
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sirius Audio Players & Recorders
Most Popular Question
12 volt power coming cradle
  • Audio Players & Recorders
